Storage Tanks as Drainback Tanks
Last Post 30 Apr 2009 05:40 PM by tomgocze. 4 Replies.
jbaronUser is Offline
19 Apr 2009 01:12 PM
What would the reasons be for NOT using a series of 120 gallon storage tanks as the drainback tanks in a large-ish solar heating system?  That is, can I avoid the use of a 20 gallon drainback tank in a 6 panel system by using the serialized storage tanks in the basement instead?
There must be some reason for not being able to do this, but I cannot for the life of me determine what that reason might be...
Thanks much in advance,
Jeff
zircoteUser is Offline
19 Apr 2009 05:37 PM
The drainback tank is set up to hold the volume of water in the collectors. More collectors more evening storage bigger tank. No need for a larger tank.
If your system is in a moderate climate the drainback will be fine. But if the systems for a pretty cold climate you should consider a glycol system.
19 Apr 2009 06:18 PM
I understand how drainback systems and glycol systems work.
My question might be better phrased like this: Can I use one or two or three 120 gallon storage tanks as my drainback tank rather than having a small, 20 gallon drainback tank with a heat exchange setup between the drainback tank and one, two, or three 120 gallon tanks?
Jeff
19 Apr 2009 07:21 PM
Sure. The reason you would usually use the standard unit would be price.
Tom in MaineUser is Offline
Check out www.americansolartechnics.com.
