Please don't let the lower up front cost of methanol distract you from the down-sides. Ethylene, Propylene or Corn-base Propylene Glycol are better alternatives to methanol. Corn Glycol products have the lowest corrosive results I have seen, allowing higher temperatures and longer replacement intervals and the mixed use of stainless steel. (It is more viscous, however.) Methanol would require acidity and corrosion inhibitors/monitoring; corrosion problems are accelerated by the use of tap water instead of deionized or boiler/distilled water! Both Propylene and Corn-based Propylene Glycol are safe for pets and ground water if leaks occur, unlike Ethylene Glycol.
see also:
http://www.oee.nrcan.gc.ca/publications/infosource/pub/ici/caddet/english/r413.cfm?attr=20
http://en.wikipedia.org/wiki/Geothermal_exchange_heat_pump
http://www.geoecs.com/14.html
and don't forget to Google methanol corrosion |
