Payback how many years
Last Post 18 Mar 2011 05:26 PM by jonr. 25 Replies.
fallguy
| 10 Dec 2010 01:34 PM |
It seems to me that wind and solar power the payback is way too long to make it worth while. I have done some reading and everytime i run the numbers it just seems to be a waste unless you are in a area where there is no grid.
Am i right? if not can you point me in the direction of a product that would pay its self off in less that 5-10 years. |
Brock
| 11 Dec 2010 10:48 PM |
Nope your right. I looked at a whole house backup genset with auto switch over and all that and then in to solar. I figured for about twice the money for solar I actually use the solar almost every day and still have a great backup power setup. I couldn't calculate the payback on a backup genset, but I can on a solar setup |
Lee Dodge
| 12 Dec 2010 08:03 PM |
fallguy- I have a 3.15 kW PV system in a sunny part of Colorado with an annual average solar insolation of 5.9 kWh/m2/day. Using PVWatts v2.0 for my area with an efficiency factor of 83.5% as given by my manufacturer, the predicted power for one year is 5152 kWh. For the 7 months that they have been installed, they are making 16% more than the PVWatts v2.0 predictions to date, but let us assume that the performance is as predicted by the model. Taking the 5152 kWh at an estimated average price of $0.098/kWh, this equals $505 worth of electricity for the first year, assuming that I displaced that much electrical use (my actual use is less than this). The cost for my system was $5451 after the rebate by the utility of $2.45 per DC watt, and the 30% of the hardware cost credit against my income tax . Assuming an inflation rate for energy of 6% per year, excluding any interest that I might have received by investing the $5451, and excluding any maintenance costs, then the system will be paid off in a little less than 8 years. I could claim that after that time, I am receiving free electricity for the rest of the 25-year lifetime of the system. This analysis does not take any credit for an increase value for the house at resale. That is an acceptable payback for me, and is better than most of the things that I waste money on. It provides entertainment for me to see my meter run backwards, and to realize that I am not sending money to Iran's Ahmadinejad when I turn on the lights around here. Lee |
JPM1730
| 14 Mar 2011 02:20 AM |
Lee, Would love some details on your system, it sounds like you have a $5,000 system that is providing 20-50% of your power needs, that sounds nice I did a ton of research into residential wind, and found it just didn't make sense....... a decent wind turbine that in reality might provide 20-30% of my power would cost about 12 grand installed after rebates, ok, that comes up to about a $30 per month savings in electric bills, so my payback would be about 30 years, assuming it never broke down. Also, with wind, they all say, oooo, watch your meter roll backwards, etc.etc... but in reality if you do some heavy digging you'll find most people get about half of whatever its actually rated for. IN the end, wind at the current prices doesn't make sense from a money perspective However lees system with a 10 year payback isn't all too bad.... Wind and solar will make sense, when you can get the payback down to 5 years The other thing to consider is peace of mind, if the power goes out for a long period of time, the ability to make some of your own power form wind or soalr could be something that helps you feel more self sufficient. |
Como
| 14 Mar 2011 10:19 AM |
I also live in Colorado, I know of no grid tied system that is economic without subsidies. Where I am there are none, elsewhere they are being reduced making the numbers less attractive. A grid tied system will not make you self sufficient. |
ICFHybrid
| 14 Mar 2011 11:26 AM |
There are systems available now that allow grid-tied alternative energy sources to be utilized when the power grid is unavailable. |
Lee Dodge
| 14 Mar 2011 12:54 PM |
JPM1730- The PV system that I have is a high-quality, professionally installed, 3.15 kW-DC rated system. The installed price in April, 2010 was $18,337.28. The rebate from the U.S. government was 30%, or $5501.18, reducing the price of the system to $12836.10. The rebate from the local utility supplier, Xcel, was $2.35 (or $2.45) per watt, or $7402.50, reducing my cost to $5433.60. Xcel is trying to do away with the rebate, and that issue is up for review by the PUC. (Como, when you say you live in Colorado but do not qualify for rebates, the federal rebate of 30% applies for you unless you do not live under the U.S. tax system.) The performance of my system and the electrical use at my house are publically available at http://www.ResidentialEnergyLaborat...se_pv.html. Between June 1, 2010 and Feb. 28, 2011, the PV system generated 4495 kWh. Using DOE’s PVWatts 2.0 to extrapolate energy produced through the end of May, the yearly output will be 5697 kWh. (As can be seen from the web site above, the actual power produced has been higher than PVWatt predictions every month, so it is conservative to use that model to extrapolate for the last 3 months of the first year of use.) My electrical usage for the seven months that I have been in the house full time has averaged 253 kWh per month. Extrapolating this for the 12 months in a year gives 3038 kWh per year. Thus, I am generating 187.5% of what I use (or 1.875 times what I use if you don’t like percentages). This electrical usage is lower than average, and the background for that can be found at http://www.residentialenergylaborat...on_am.html. The fact that I generate more electricity than I use allows me to offset the natural gas that I use for space heating and supplemental water heating and cooking, and meet my net-zero source energy goal. However, a better economic trade-off is provided by NOT over-sizing the PV system relative to electrical needs (at least at my location). So the “hard facts” are available above for costs and energy generation and usage (with documentation on the web site), and how one treats these facts becomes the subject of some debate. Let us assume that my system was not oversized relative to my needs, and that I was using all the electricity that I generated. This is more typical of most households. Current residential electric rates in my area are $0.9974 per kWh (roughly 10 cents/kWh) for small users. Further assume that the electric rates scale with natural gas prices that have increased in Colorado at an annual rate of 4.7% since 1990. Then keeping that same inflation rate, after seven years I would have paid $5540 for electricity without a PV system, but, as shown above, I paid $5433.60 for the PV system. Therefore, I could say that for seven years, I pay the same price for electricity with or without the PV system, but after year seven, I get electricity for free for the life of the system (perhaps 25 years total). Without the Xcel rebate (Como’s case), the payoff would be a little more than 14 years, at which time regular electricity bills would have cost me $12,373 versus the PV system cost of $12,836. This analysis ignores the 0.5% interest I could get if I deposited the money in a bank savings account instead of the PV system. My system is grid-tied, and it would cost another $8,000 to modify the inverter system to allow it to operate when the grid goes down. I have another small PV system in Texas that is not grid-tied, and dealing with the batteries is a nuisance. Lee Dodge http://www.ResidentialEnergyLaboratory.com
in a net-zero source energy modified production house |
karikco
| 14 Mar 2011 06:49 PM |
What you are talking about is "Simple Payback". Simple payback means "How long before I get every penny of my investment?" On the surface that seems a logical question. The problem with the way of this thinking is it is extremely short sided.
Investing is an Act; laying out money or capital in an enterprise with the expectation of profit. Simple payback is not profit. Nor is it a real investors way of thinking.
I have a book available "Solar PV an Investment Strategy" I would be happy to share with you. Contact me at [email protected]
Karyn Nelsen Upshot Energy Corp |
Como
| 14 Mar 2011 10:17 PM |
My supplier is IREA and unfortunately my business is not making any money so the tax credit is currently useless. Now if they sent me a cheque... But lets say that was not an issue. My rate is 11c, so lets say that is $700. So $13,000 investment gives me a 5% rate of return. Hopefully increasing over time, without the tax credit it is 3%. but then the system has a finite life span and requires some maintenance. So without subsidies it is nonsensical. Hopefully prices will continue to fall so it becomes a more practical proposition. I am putting in a Biomass system, the numbers there are much more attractive, wood being 1/10th the price of propane per btu. Wind is worse than PV, unless maybe if you are on the Easter Plains. Much more maintenance. Without the distortion of subsidies for most people Solar DHW is a much better bet than PV. |
| 14 Mar 2011 11:14 PM |
Agreed, alternative energy subsidies are a distortion attempting to make up for another distortion - artificially low energy prices. Charge for all the environmental damage, depletion for future generations, wars, etc. Then things will take care of themselves. |
Lee Dodge
| 15 Mar 2011 12:28 AM |
Como- Last year’s defense budget, including overseas contingency funding, was $663.8 billion. If I assume that 20% of this was to invade and occupy the country with the world’s second largest oil reserves, and to maintain a huge presence in the Persian Gulf region to safeguard the 4.1 billion barrels of imported oil per year, then I compute a subsidy of $0.06 per kWh for electricity generated from imported oil. (This includes no value for the 4,439 American lives lost in the Iraq area, the 32987 Americans wounded, and maybe 100,000 citizens of Iraq killed.) This would increase electrical costs in my area from $0.10 per kWh to $0.16 per kWh if generated from imported oil. Now electricity here is mostly generated from natural gas and coal, but the U.S. shares a pool of available fuel supplies, and increases one place impact the rest of the country. Further, oil companies claim the enhanced oil recovery credit, and intangible drilling cost deductions, increasing my tax burden, although I use no oil or gas for production of my electricity. So we are directly and indirectly subsidizing the production of oil from both domestic and foreign sources. This oil production has also provided the recent Gulf of Mexico oil spill, as well as CO2 when it is burned. "Energy indepedence" for Republican Mitch McConnell is to drill faster so that we can more quickly use up the other half of the petroleum that we have not already burned up. I would prefer that my tax dollars subsidize a renewable energy source that will be here long after the petroleum is gone. So why would you comment about the subsidy for solar energy, and not acknowledge that there are significant subsidies for other non-renewable energy sources? Lee Dodge http://www.ResidentialEnergyLaboratory.com in a net-zero energy modified production house |
Como
| 15 Mar 2011 01:28 AM |
In Colorado I do not believe any electricity is generated from oil, mainly from coal and more coming from Natural Gas. I would rather they kept Natural Gas for other uses, seems a waste for a high quality fuel. Mind you if we had NG, I am not sure if I would have gone biomass. We actually sit on a coal seam, but not economic to operate. Coal is something that generates local jobs whilst PV panels seem to come from China. The moralistic issue I have is that your kick back came from Xcel, Xcel funded it from a general levy on rates so you have the poor subsidising the wealthy, just does not feel right. A bit like the lottery.
| 15 Mar 2011 08:59 AM |
Each coal plant kills at least 10 people a year from the pollution it creates. Makes nuclear plants look quite safe.
Como
| 15 Mar 2011 09:26 AM |
How many deaths is each McDonald's responsible for? If that is going to be the determining factor, Nuclear would be the best option. http://nextbigfuture.com/2011/03/deaths-per-twh-by-energy-source.html
Lee Dodge
| 15 Mar 2011 12:47 PM |
 Fig. 1. Suggested long-term energy approach by jonr and Como.  Fig. 2a. Suggested long-term energy approach by Lee.  Fig. 2b. Suggested long-term energy approach by Lee. Lee Dodge http://www.ResidentialEnergyLaboratory.com in a net-zero energy modified production house |
ICFHybrid
| 15 Mar 2011 04:52 PM |
so you have the poor subsidising the wealthy, I can understand your objection there, but let me also point out that the poor have at least an equivalent stake in the big picture which is achieving some sort of sustainable energy plan sooner rather than later. If things go poorly in the long run, even if it is just spikes in energy prices, not to mention significant shortages, they will be the ones suffering the most. Does Excel Energy have some sort of Green Energy program in which customers (who, presumably can afford it) voluntarily pay a premium on their electrical rates in order to subsidize investment in Solar? |
Lee Dodge
| 15 Mar 2011 05:34 PM |
ICFHybrid- I am not aware of Xcel in Colorado having such a program. City Public Service in San Antonio, Texas had a program that like for wind energy, so customers could pay a premium on their electric rate, and the sum of all those customers times their fraction of wind energy selected determined the amount of wind energy that the utility was obligated to obtain. When they first introduced it, they still charged me a fuel adjustment charge in addition to the wind premium, and I told them they were inconsistent and dropped it. When they finally dropped the fuel adjustment charge, I signed up again. I don't know how successful the program was, but there are a lot a wind generators in west Texas and in the Panhandle. Interestingly, the first requirements for renewable energy in the utility mix in Texas were put in place when George W. Bush was governor, or at least there were significant increases in the requirements at that time. Lee Dodge http://ResidentialEnergyLaboratory.com in a net-zero energy modified production house |
Como
| 15 Mar 2011 10:44 PM |
New Belgium brewing used to advertise that they were wind powered, they were not, coal, but paid the surcharge so they could say they were. Just looked at is seems that they have stopped. |
ICFHybrid
| 16 Mar 2011 12:46 AM |
Have you checked out the Sierra Nevada brewery? They have some PV panels. And a fuel cell. And a methane gizmo... |
| 17 Mar 2011 03:13 PM |
Posted By Como on 15 Mar 2011 09:26 AM
The whole model of large central generators separated from the loads by large distances of grid is less secure, less stable than the same generating capacity generated more locally to the loads. Solar, while predictable in output by the weather, requires substantial "hardening" to be a reliable base-load generation source. (With smart grids and smart-batteries in an electrified automotive fleet it can provide something less ephemeral though.) If the backup for distributed PV is the grid, it imposes a higher capital cost for generation capacity on the backup-end that doesn't appear in the capitalization cost of the grid-attached PV array itself. Not saying it isn't worth doing, but smart grids & smart appliances might be a cheaper/better way to manage the grid as a whole. Idle grid generators are expensive and un-green, as is power-dumping by oversized base generators that can't track loads over 24 hour periods, such as nukes, which can be throttled back quickly but take days to come back to full capacity. (You can't thermally cycle coal plants very quickly or efficiently either.) Distributed natural gas fired mini and micro cogenerators can be quite flexible for grid hardening of solar/wind, since daily thermal loads are predictable, and thermal storage in tanks can be easily managed over the course of hours/days. By not simply dumping the thermal output, cogens are significantly more efficient than even combined-cycle gas generators, and far more flexible, achieving source-fuel efficiencies comparable to mod-con boilers or condensing gas furnaces, but with a mixed power/heat output. This approach is currently being developed on a large scale by the utility LichtBlick in Germany, for grid-hardening their substantial wind power investment. They're using VW powered cogens & 1000+ gallon tanks with small building or house-sized thermal output, all under the remote control of the utility, who guarantees the building owner that their thermal loads are met. The building owner pays the fuel, but gets essentially free electricity, and all maintenance is performed by the utility. They're on track to installing a couple-nuke's worth of highly flexible peak capacity before 2015. There are many parts of the US (most of it, in fact) where a similar model could be used to good effect. Gas-fired chillers' peak loads coincide with peak electricity loads, space heating loads have similar profiles, and the thermal output is storable for days. With distributed generation, the grid is less susceptible to the types of interruptions being suffered this past week in Japan (even when you take the meltdown out of the equation.) Whole chunks of the distribution grid can be taken down in such a scenario without having to resort to rolling blackouts, and if local generation capacity is reasonably sized to local loads, the generating capacity that's taken out in a disaster is only what was feeding the likely-damaged end-use load infrastructure. With remote large central generators broken transmission lines or generators going down cripple the entire system. By any factor, there is no one "best option". But large-scale generation is expensive, slow to build/deploy and not very flexible at all. |
190 |
190 |
