Posted By NetComrade on 15 Mar 2013 09:37 PM
Dominion has a program for a grid-tie system where they'll buy all of your power for systems up to 20kW (although they discourage systems over 10kW with fees). First, does anyone know of pros and cons of the programs? I am not completely following the link
http://www.dailykos.com/story/2012/08/13/1119761/-Dominion-s-Solar-Purchase-Program-Undervaluing-solar-overcharging-green-power-customers
My other questions:
Does forum recommend having both inverter solar power (110v) as well as 24V in a couple of places throughout the house? My house would be one story and 3000 sq feet (about 160 feet in length, as it will be stretched shoehorn shaped.
Does forum recommend 220V or any high usage appliances is fed directly by power company (e.g. AC) w/o any inverter?
This sounds like a very common Netmetering program offered by many Utilities. They're usually a good deal, and I would recommend an inverter, with only the typical 110VAC and 220VAC outlets in your household. Your Utility probably won't allow a switch from the inverter to a home DC system. Also, you will probably have to provide external disconnects, so the utility can remove you from the grid, if they have emergency maintenance to perform.
My guess is, that you will also need some type of permit in your area, and that the Utility will require a copy of the permit, before approving your Netmetering account.
Lots of pros to a Netmetering system. The only con is that you will probably still get an electric bill, even if you consistently run a surplus. Utilities all have a fixed fee that they charge for meter reading, etc. Mine just recently went from $19.95 a month to $29.95. I wasn't happy about this, and I called, and had a very long conversation with a company representative. He told me that their goal is to recover all operating expenses except for their power purchase, with the Fixed Fee. They actually lowered the Usage Fees, when they raised the Fixed Fee!!! He told me that, just 10 years ago, they didn't operate that way. The fixed fees only covered a small portion of their operating expenses. I believe that this policy is very "anti-renewables" in it's approach.
