So how do you physcially enter the home with PV wiring? Best methods?
Last Post 06 May 2013 10:20 AM by acwizard. 4 Replies.
JohnRLeeUser is Offline
04 May 2013 10:46 AM
Maybe this has been discussed but what are the most orthodox ways to get one's PV wiring into the home.
I see 2 potential routes:
1. Down the roof and enter up under the eave/soffitt.
This would be uglier than method 2
2. Breach the roof with a grommeted "service entrance" (gray PVC periscope type of hardware).
Some may be squeamish about breaching the roof but it's done all the time for drain vents, etc...
ICFHybridUser is Offline
04 May 2013 07:08 PM
It's grommeted service entrance.
05 May 2013 08:37 AM
Posted By ICFHybrid on 04 May 2013 07:08 PM
Thank you.  Something like this?
http://cloudfront.zorotools.com/product/full/4FYU9_AS01.JPG
05 May 2013 12:38 PM
The weather head is nice, but it might be a little unsightly depending on your installation. Also don't know if your installation will be considered high voltage or low voltage as far as code goes. I actually used one of those weather heads to enter 4 insulated flexible pipe sets for the hot water solar panels.
I have two pieces of 1" rigid metallic conduit coming up from a junction box in the house for the PV panels. They come up right under one end of the array. Since I have metal roofing, they are sealed to the roof with the standard silicone rubber boot with metal ring to screw the edges down. The wires into the conduit will get weatherproof fittings
acwizardUser is Offline
From your combiner box run a conduit either emt or ridgid depending on local codes down thru a approved roof jack and then seal conduit to roof jack with sikaflex or silicone, roof mastic will also work.
People Online People Online: Visitors Visitors: 190 Members Members: 0 Total Total: 190
