Posted By moibiusmuse on 01/04/2008 10:56 PM
1. I was originally set on doing the large window areas as glass block. I am not building on a vista lot, and I presumed the R-Value on glass block would be significantly higher than insulated windows and provide privacy without having to use blinds or curtains to prevent visibility into the interior. I then read recently that modern insulated windows have the same R-Value as glass block. Has anyone heard either anything to confirm or deny this?
Actually, some windows have a
higher R-Value(It's usually expressed as a U-Value). For Glass block, figure somewhere around R-2. Also, glass is a thermal conductor, and a glass block usually has conductivity between the outside and the inside.
2. I have since wanted to look into insulated windows, but still like the idea of the privacy that the glass block provides. Does anyone know of vendors or product lines that offer insulated windows that are not translucent but either frosted or otherwise altered to prevent visibility in while still allowing all the light into the spaces.
I don't have a pointer, but I've seen windows that use electricity to change from clear to opaque.
3. Does anyone know if there common building codes that require windows to be used as a means of egress from the house? If I choose glass block for windows, are there some minimum number of windows that would need to be kept openable for the purpose of egress?
Every bedroom must have an egress window. I have a client who tried to use a master bathroom window as the egress window for the Master BR. The building dept shot that idea down, and they had to find another wall in the master in which to create that window.
