Posted By green78 on 02/03/2008 9:03 AM
My question is what company makes good quality windows. I have looked at Pella, Hurd and Sun.
Now I for one have never heard of Sun. A good source of data is the National Fenestration Research Council, http://www.nfrc.org. But, you will find they list over 600 window manufacturers so good luck getting any kind of consensus from any group about which are the best.
Frankly, your question is a typical Ford vs. Chevy question. There ain't no easy answer!! Anybody who gives you a strong opinion about which window is best is either ignorant, biased, limited in the number of windows they've worked with, or found one they're happy with and stopped looking at others.
Me, my top two choices would be Vinyltek out of Canada and Andersen. I like the ease of operation of Andersen casements and the one piece vinyl cladding on the exterior frame and their price is tolerable. That's what I'm using on the house I'm ready to build. Vinyltek are super windows, but the local sales outlet is a siding and replacement window company so the price is out my reach. Pella are good windows but I don't care for the aluminum cladding which is multiple pieces. Aluminum conducts heat very well so I don't like it anywhere where you need a thermal break from outside to inside. Most vinyl windows have frames that will move and twist and turn with sun heat and age and start leaking in just a few years. Some of the best windows available are made in Europe, but they have an European price tag. One bit of information you can sift out of all the data is the conclusion that casements, and probably awning, have the best fenestration data of all windows, i.e., they are the tightest when it comes to air leakage. Also, cheap windows properly installed are just as good as high grade windows poorly installed. So bone up on installation and waterproofing techniques as well as window quality.
There, now you have some of my biased thinking based on the limited number of windows I've looked at and after which I stopped looking!!!! I sure hope none of it is ignorant thinking!
Go to the exterior finishing forum at JLCOnline.com and you'll read a lot of comments about windows, good and bad. It's interesting how some contractors will passionately argue one window is absolutely great while another contractor will just as passionately argue they're a piece of dung.
Do a lot of research, read a lot of opinions, allow yourself to become confused and frustrated, and then start sorting out the features and characteristics that matter to you. When you find a window you like, at a price you can accept, that does what you want it to do, stick with your decision. Let no one other than Father Time tell you you screwed up, if in fact you did!!! And by the time he tells you, it'll be too late to change!
ONE WORD OF CAUTION!!! From what I have found, there ain't no such thing as standard window sizes. If you size your rough opening for a Pella, you'll play hell getting an Andersen to fit in it. I suspect it's pretty much the same among all window manufacturers. So be sure to choose your window first and then design the hole to fit it. Don't try doing the reverse or you'll gladly let your wife and kids beat you up for stupidity. Maybe it's not THAT bad, but damn close!!
