Posted By MBURR on 12/31/2009 11:01 AM
during a hurricane a outswing door will be pushed up against the door jamb and will tighten the seal keeping more air out. Inswing doors will be getting pushed into the home allowing more air into the home which is why most homes are blown away because the air rushes in and causes the roof and walls to bow outward until they fail causing catastrophic failure of the structure. While i was wrong in saying they are required. Out swing doors are highly recommended in areas of high wind. Just like a Casement window has a better seal than other windows outswing door do as well.
MBURR;
during a hurricane all claddings, doors and windows are exposed to both positive and negative pressures, and while you explained how the outswing door performs during positive pressures, you did not answer the question about how it performs during negative pressures.
with your reasoning, siding would also stay on the house because the wind is pushing against it and holding it there?
Instead when the wind is blowing parallel to the door or from the opposite side of the house in causes "negative pressure" (sucking away from the framing ) at which point you would loose the seal from the outswing door and increase it on an inswing door.
It is not uncommon in a hurricane to have 1200 lbs. of negative pressure (outward) on a 3/0 x 6/8 door.
The newest inswing or outswing doors are designed to withstand these forces and neither an inswing or outswing will perform any better in a hurricane.
door failure is not the reason causing catastrophic failure, but rather in both hurricane Andrew and Charley it has been attributed to the roof sheathing failure either thru negative pressure on sheathing or thru postive pressure entering thru the vented soffits.
Another good reason to build with unvented roofs. The newer codes have increased the nailing patterns to help prevent the plywood from getting ripped off.
The reason a casemnet window seals better is because of the camlock holding it tightly to the weatherstrip.
Sooooooooooooooo getting back the original question about which doors are better for efficiency, we have found during blower door tests the inswings perform better.
And during a hurricane.......... efficiency is the least of your worries?
