Insulating a pole barn
Last Post 15 Sep 2011 08:03 AM by smartwall. 8 Replies.
arcammUser is Offline
31 Dec 2008 06:19 PM
I just built a pole barn, it 24" by 40" with 10' walls and a 4/12 roof.  I want to heat it with radiant floor heat.  I'm trying to figure the best way to insulate it.  My first choice is closed cell spray foam, but the budget will only allow 2".  I want the structure to be as tight as possible and plan to use a HRV to control air quality.  Am I on the right track or does anybody know a better way?  The building is located in Central Maryland.  Thanks,
01 Jan 2009 08:00 AM
Posted By arcamm on 12/31/2008 6:19 PM
What is the building to be used for?
01 Jan 2009 11:56 AM
The building will be a metal/wood shop. It will be heated by a radiant system in the slab. Winter heating requirements would only be up to 60 deg F.
01 Jan 2009 12:07 PM
Posted By arcamm on 01/01/2009 11:56 AM
2" is probably OK for a shop, I question the neccesity for a HRV, an exhaust fan is probably better suited for fume and dust, your air infiltration will be around door and window openings, unless you provide another fresh air supply inlet near exhaust.
If you are already having trusses, purlins and girts like a traditional pole building you may want to consider 2"-3"steel SIPs that already have the roofing and siding integral with panels. saving a step and providing a clean washable interior surface
01 Jan 2009 12:44 PM
This building is kind of an experment. I'm trying to build the lowest cost ($25 to $30 per sqft), most energy effiecnt stucture I can. The goal is to get it as air tight as possible, that's why I chose the closed cell foam for insulation and air barrier and the HRV for air quality.
I looked into sips, but the cost factor ruled it out. It would be my choose for new living space. Great idea about using it for the roof. I still have a Garage to build. What kind of cost are these steel sips? I was told by a local sip builder to figure $10 sqft installed plus surface coverings for wood covered sips.
01 Jan 2009 02:56 PM
Posted By arcamm on 01/01/2009 12:44 PM
the advantage over the wood sips is you are kiling several birds with one stone and replacing several components all at once....... insulation, vapor barrier, exterior paint, interior finish/paint, soffit, roof and wall coverings for about the same or slightly higher as wood SIPs
Attachment: hr900.jpg
PolycoreUser is Offline
12 Jan 2009 05:02 PM
Just completed a 70' x 40' "Versa frame" shop in two weeks, start to lock-up. We used the versa frame as the structural frame for the shop. We then sheeted the sides and roof with 4' x 11' 8" EPS and structural steel panels. The steel embedded in the EPS acted as the purlins and girts and the outside was ready to be cladded. The end product was a R36 insulated shop that was erected sheeted and locked up in less than two weeks. I have attached some photos of the project, if you want more information feel free to PM me.
Cheers,
Attachment: versa1.jpg
Attachment: versa2.jpg
Attachment: vesa4.jpg
Polycore Canada Inc.<br>www.polycorecanada.com<br>1-877-765-9267
14 Sep 2011 07:47 PM
Posted By siteturbo on 14 Sep 2011 04:40 PM
For those of you interested, I found a forum dedicated directly to barns at www.BarnsBB.com :-)
What was the cost per square foot for that kind of structure?
smartwallUser is Offline
I installed insulation in a similar situation a few years back. It was an auto salvage yard that used a pole barn for taking apart engines and tranys. The owner used stell siding on the inside because of the grease and oil. He ran the siding sideways from the botton to the top so he could pressure wash the walls and used a raised heel truss inside the building framework. This allowed for a balloon frame into the attic thru which we blew 8" of cellulose into the walls and on R-50 in the ceiling. If I remember right the wall area was about 5000sq ft net and the ceiling was 5000 sq ft. Three men did the whole thing in 1 day and the price knocked every other system out of the box as far as r-value and cost.
People Online People Online: Visitors Visitors: 153 Members Members: 0 Total Total: 153
