Selecting green or sustainable products for your project
Last Post 25 Jul 2011 05:14 PM by KathleenWillem. 26 Replies.
RunkaUser is Offline
02 Feb 2010 12:11 AM
There are many products on the market that claim to be green. It is up to you to determine which products are green and which are not. Beware of "green washing"! Many products are advertised as green, but after review really do not live up to their claims. Here are few factors to consider when selecting green or sustainable products and materials for your project.
Renewability - Are the products made from material that is rapidly renewable such as cork or bamboo? Wood products are also a renewable resource. Choose wood products that are FSC (Forest Stewardship Council) certified. Many engineered wood products are made from fast growing trees such as aspen and require less wood to make them than conventional lumber.
Recycled Content - Using material with recycled content not only reduces strain on our landfills, but reduces the need for raw material. Paper, cardboard, plastic, steel and aluminum are a few of the most commonly recycled materials. Recycled paper is used in cellulose insulation and paper countertops. Plastic is used in carpet. Metals that are recycled can be made into their original form.
Reusability and Recyclability - Many products, such as metals, can be recycled after their useable life. Others can be salvaged and reused somewhere else.
Durability - Choose products that will stand the test of time and require little maintenance. This will save time, money and energy on repairs at a later date.
Embodied Energy - This is the energy used to produce, transport and install a product or material in the place where it will be used. Choose local products when possible and products that do not require a large amount of energy to produce.
Air Quality - Products like carpet, cabinetry, plywood and paint can contain petroleum products or formaldehyde and off gas VOCs (Volatile Organic Compounds). There are now many products available that give off little or no VOCs. These products will give you a healthier home to live in. When you are not able to find suitable products, ventilate the new or remodeled space prior to moving into it. Open windows and doors when possible to remove the VOCs from the home.
Waste Reduction - Choose material that does not create a lot of waste and can be used efficiently. Order material in sizes and lengths that are efficient for your job.
Runka.com - Environmentally friendly green products
02 Feb 2010 03:20 AM
Runka;
wood is predominantly used in construction and yet I see dumpster loads of scrap going to land fills.
I fail to see the "green-ness" of using wood for framing without regard for recycling the scrap.
any thoughts?
09 Feb 2010 01:29 AM
Posted By cmkavala on 02/02/2010 3:20 AM
Runka;
any thoughts?
Rightly said, I totally agree with that.. Some steps or laws should be undertaken immediately.
After your post, i was just considering, how many people are engaged in using wood for framing & have no thoughts of recycling the same.
Any suggestions, you think should be undertaken..?
09 Feb 2010 03:28 AM
Runka;
Glad I made you think!  there certainly is a use for scrap lumber other than the land fill,  steel and concrete are both recyled.
We use very little wood, consequently there is very little wood scrap on our jobs, we do recycle our steel and EPS, we try to minimize the burden on landfills
I think the wood industry "touting" the green-ness of their products should further their efforts to recycle the scrap into OSB, fuel pellets, etc., anything but rotting in landfills
rustyjamesUser is Offline
16 Feb 2010 02:46 PM
Actually, many haulers are seperating the materials from construction sites and diverting those materials from the landfill.
17 Feb 2010 05:38 AM
Posted By rustyjames on 16 Feb 2010 02:46 PM
Really where?
17 Feb 2010 09:29 PM
I see a lot of framers burning their scrap wood in barrels on the job site.
18 Feb 2010 08:59 AM
Burning scrap wood on the job site destroys the evidence of waste.
19 Feb 2010 12:41 AM
Posted By Alton on 18 Feb 2010 08:59 AM
So, there is no way to stop and put a check on this!!
19 Feb 2010 08:52 AM
My area now has a rule that one can not have an open fire within 500 feet of a residence.  Builders are now using roll-on dumpsters to carry waste to the landfill.  I have seen as many as 4 big dumpsters filled with waste while stick-building a residence.  This new rule does not reduce waste but does keep the nearby homes free of smoke.
19 Feb 2010 06:08 PM
Most urban areas around us have burning bans, but the rural areas are usually allowed to burn.
I can remember in the 80s, when US homes would deliver the wrong trusses to a model, they did not get moved , they went to the landfill.
21 Feb 2010 02:03 PM
So far I haven't rented a dumpster for my site yet. It makes you very conscious of waste when you have to figure out what to do with each piece of it instead of just tossing it all in a dumpster.
21 Feb 2010 06:13 PM
Posted By Jelly on 21 Feb 2010 02:03 PM
strip skins and recycle steel
Green_lightingUser is Offline
08 Apr 2010 03:34 PM
Yes! I am sick of these green "claims"!
For example, our apartment building claims to recycle, yet there is no discernible separate dumpster for recyclables?!
We need to start hold companies and entities accountable for EXACTLY what they mean when they advertise something as "green" or "energy efficient."
Green_lighting
Your source for green lighting since 2002.
www.electricalmarketplace.com
bobarchitect39User is Offline
15 Jun 2010 10:40 AM
Until there is some kind of clear-cut and set in stone regulations and guidelines, there is not going to be enough pressure on builders to abide by these methods and practices.  If there is nothing that holds the builders accountable for it (not to mention that it most likely becomes an expense) then the problem is only going to continue.
16 Jun 2010 04:42 PM
Posted By bobarchitect39 on 15 Jun 2010 10:40 AM
Bob,
green practices are not code requirements, don't expect most builders to do anything green related unless there is something in it for them.
17 Jun 2010 10:53 AM
Completely agree with you and that was my point...
Not even worth discussing if there is nothing in place that is MAKING builders operate this way.. until then, it will be about the $$$$.. and right now can't exactly blame them.
26 Jun 2010 02:52 PM
bobarchitect39;
You can't entirely blame builders, you don't see the nations large builders participating in the GBT. They respond to what most consumers want ........... with new home features,  the homemaker is usually the decision maker. Given the choice of stainless steel appliances and corian tops vs. a 15 seer HVAC system,  which one do you think is more appealing?
BUT! , I think some of the more intelligent home consumers do want energy efficient or green features. Home trends are consumer driven. Homes like cars are an extension of our personality, so many would choose style over being practical.
If you hang around the GBT you are one of the more informed consumers and one of the building professionals that care about providing a better product.
Builders will change when the buying dollars shift to green
29 Jun 2010 11:51 AM
Couldn't agree with you more, it is about the consumer.  Not sure what it is going to take for this shift in views and demand to occur, but for the benefit of the industry and sustainability, lets hope that it is a trend that is beginning soon.
12 Jul 2010 11:59 AM
Posted By cmkavala on 17 Feb 2010 05:38 AM
Really where?
Right here in the beautiful state of NJ.
People Online People Online: Visitors Visitors: 160 Members Members: 0 Total Total: 160
