heating source help needed
Last Post 17 Apr 2012 12:23 PM by gtjp. 3 Replies.
rzitojrUser is Offline
17 Mar 2012 10:00 PM
I am looking to lease a storefront. My intention is to open a pharmacy. The store currently doesnt have any heating. But I do see a gas supply line for a water heater connection. Would a water heater be able to provide adequate hot water temperatures for baseboard heating? Keep in mind, the temperature in the pharmacy must stay at or above 59 degrees, at all times.
acwizardUser is Offline
18 Mar 2012 03:53 PM
The simple answer is probably no.Would need to know the square footage of the space and the design outdoor temperature along with the number of occupants etc.
RosalindaUser is Offline
18 Mar 2012 09:20 PM
Depending on your heat requirements - maybe a high efficiency hot water heater such as a Vertex 100 might work - but you might be better off with a boiler, even if just a small efficient wall mounted one.
GTJONUser is Offline
Does it get to zero?
30% glass to walls?
Side stores heated?
Dark clear night , windy, ? Feel anything leaking all over the front door and frames and window(s)?
Basement cold?
Back door leaky?
Lifestyle interior temps desired?
Coldest peak, hottest peak, (s) and average according to neighbors...?
DEGREE DAYS from your weather bureau or local HVAC friend ?
and more ?'s
but maybe put what you can on Load form with roof-attic description, let's see: GEOPros.org (click logo)
rough site to hand to pro, but form works for more accurate helps from me.
People Online People Online: Visitors Visitors: 160 Members Members: 0 Total Total: 160
