I haven’t had any experience yet using Venturi Showerhead; however, what you should know is that what type of showerheads you are going to avail as it should suits your taste and preference.
There are
four types of showerheads available in the market such as fixed showerheads, shower body jets, shower handsets, and dual showerheads.
Fixed showerheads would allow you feel like bathing in the rain and its water flow is steady, nevertheless, its disadvantage is that it has a limited mobility due to the fact that it is fixed to the wall. Therefore, you will not get a chance to have a very thorough hair washing as you cannot draw it nearer your head.
Shower body jets are designed for them who are not satisfied with a fixed showerhead which has a steady downward water flow.
Shower handsets act both as fixed showerheads and shower body jets. You can choose to fix it by placing it into a bath cradle in a hanging position and you can also remove it there and be directed to spray water to specific body parts.
And lastly, the Dual Showerheads consist of two showerheads connected by a finished metal bar. It is fixed to the wall covering more surface area and delivers twice the amount of water spray.
