AAC Block Vs. Poured In Place Cellular Concrete
Last Post 21 Feb 2010 09:33 PM by Como. 2 Replies.
pewellmanUser is Offline
16 Feb 2010 04:25 PM
I have a client that wants to build a “green” home but they will not use anything that has polystyrene in it!
I am researching AAC block and poured in place cellular concrete. The poured in place makes a lot of sense because you are not hauling the AAC all over the country. Problem is I can find very little information on this subject. And even fewer people that have experience with the process.
Someone out there have first hand experience with pouring cellular concrete?
I am thinking of building forms out of MgO board, pouring and leaving the MgO as finish surface inside and out?
Any help would be appreciated.
Paul Wellman, USGBC LEED™ AP<br>WellMan Enterprises - Construction For The 21st Century<br>Home of GreenEarth Structures http://www.greenearthstructures.com
<br>970-734-6645
ComoUser is Offline
19 Feb 2010 05:56 AM
http://www.hhcelcon.co.uk/c/document_library/get_file?folderId=54641&name=DLFE-4811.pdf AAC transportation is down to vavailability of local production, the same for any other material. AAC by itself is better than brick but not a total solution, you still need insulation. If you look on the above attachment it shows batts being placed in the cavity, they could be fibreglass or cellulose.
ComoUser is Offline
Sounds fun.
Be good, if you can not be good be careful.
People Online People Online: Visitors Visitors: 157 Members Members: 0 Total Total: 157
