Active pressure management?
Last Post 22 Mar 2010 02:18 AM by Clifto. 1 Replies.
14 Mar 2010 01:07 PM
Per various references, moisture condensation in the wall is normally caused almost completely by air flow through the wall - out while heating, in while cooling.  This air flow is caused by pressures differences that come from wind, stack effect, and forced ventilation (wood stove, exhaust fans, vents, etc).  All of these are highly variable.  So would it be possible to measure and actively manage this pressure differential?  Ie, pressure sensors and fans that would always maintain the right pressure to prevent warm, moist air from moving towards the colder surface?  Ie, make sure that the house never sees any positive pressure in the winter?
CliftoUser is Offline
Hello guys!
Thanks for the above information and its all depends upon the environment change and power energy to control the warm and thannks for sharing your thoughts....
<a href="www.solarlightsmart.com">solar lighting</a>
