desparadoz
| 01 Apr 2012 12:37 AM |
Magnesium oxide board is known as magnesium board,MGO board.The main raw material is MgO and MgCl2 .It is characterized by waterproof,fireproof and Not deformation . Magnesium oxide board enjoys strong points in more fields compared with the plasterboard and the traditional partition board, either in the decoration for modem construction or the fire-resistent division for the industrial workshops Magnesium oxide board are smokeless and innocuous and 100% free from asbestos element which is harmful to human body. The board material is processed through antistatic treatment and is added with special recipes to enhance the stability. The face is smooth and free of air holes, non-reaction with halogen and not colored, thus the face is naturally smooth. The unique strongpoint of magnesium board is that it can be applied to many sites, such as office block, shopping center, aggregated apartments, steel reinforcement high-rises, bathrooms and museums, department stores, cinemas, acoustics rooms, industrial workshops, laboratories, and bathrooms and wash rooms where it is usually damp and so on .
Features of the products
Strong fireproofing capability:All the specifications of this product has reached the requirement of GB8624 fireproof level A and JC688-2006. Good shockproof capability:This product is designed with many layers of high-strength fiber webs, which can effectively absorb part of the energy from the earthquake to avoid the instantaneous collapse of the isolation wall. Smooth and scratchproof face:Advanced European and American production technology and recipes is introduced for this product, thus the turned-out board material is of smooth face and high hardness, collision and impacting will not result in depressions and scratches. Good safety performance:This product is 100% free of asbestos and radiation, nor will it create the organic substance harmful to human bodies. Superior performance in sound insulation and heat insulation: When used as the partition, this product can be filled inside to absorb sound, whose performance in sound insulation is better than the single brick wall meanwhile the cold and green house effect is raised, which saves energy and increases the economic benefit. Damp-proof and non-reaction with halogen:The advanced and special production technology and recipes is introduced to cause the board material not to expand, peel off layer after layer, go moldy or react with the halogen like the plasterboard, silicic acid board or the common glassboard because of the damp environment, thus it can be widely used in the damper places such as bath-rooms, toilets and so on. Wide applicable scope:Can be painted, jointed with wall-paper and sculpted or colored as the second processing. Bend-proof:The structure of the board material is processed specially, thus the board material is flexible and elastic.
