The problem that you are having is most likely due to a common error that is made with tight thermal envelopes such as spray foam. Oversizing of the HVAC system will prevent it from running enough. A smaller system will run more and with a lower power consumption.
During more humid days, your HVAC system is like a large dehumidifying system. When it is not running, it is not dehumidifying. If you do not make changes to the HVAC sizing, you will most likely need to install a dehumidifier in the attic. Let me know if I can help.
I am sorry to see that people continue to have this problem and it is sometimes viewed as a "black eye" for tight thermal envelopes. EnergyWise can help those looking to prevent this problem.
Scott V.
[email protected]
