concrete slab alternatives
Last Post 03 Mar 2010 05:00 AM by greenfin. 5 Replies.
bbicfUser is Offline
04 Feb 2010 10:13 PM
I am looking for good alternative to a concrete slab in my basement.  I have seen a system with rigid foam and steel studs that you have put over a compacted level gravel base and then plywood over that, but the claims of being cheaper than a concrete slab were off, so am wondering if anyone has any other ideas or if one could do the same thing themselves with rigid foam and some type of stud.
regards
05 Feb 2010 01:46 AM
bbicf;
it is possible to use AAC floor planks, but if cost is the driving factor, slab on grade is  likely the most cost effective
StyroHomeUser is Offline
19 Feb 2010 05:15 PM
Try using a EPS Foam RAFT Foundation
19 Feb 2010 09:06 PM
Which aspect are you trying to improve?
19 Feb 2010 09:11 PM
All of them;-)
greenfinUser is Offline
The slab you are suing right now i think is the best slab according to time period but if you want to change this i will recommend you to go for some wooden slab.
<a href="http://www.epdmcoatings.com/">Liquid Rubber</a>
People Online People Online: Visitors Visitors: 168 Members Members: 0 Total Total: 168
