Kama-eebs / K-Tect any opinions?
Last Post 23 Apr 2012 09:29 PM by LarryT. 29 Replies.
OdabreeUser is Offline
07 Feb 2012 01:09 AM
You can just google it. Their web page is http://www.k-tect.com/index.php
07 Feb 2012 08:22 AM
I have not used the K-tect system.  I have only seen it at the AIA Expo in New Orleans last May.  The people working the booth were very good about answering my numerous questions.  I remember the panels being limited to 20'.  Longer panels can be had by butt-joining them with G90 galvanized steel.  About the only reason that I have not followed up on this system is that the two manufacturing plants are quite far away:  Las Vegas, NV and Brownsville, TX.  Shipping long distance can become expensive.  By now, this company may have plants that are closer to the Southeast.
FTDAUser is Offline
07 Feb 2012 08:46 AM
PolyCore in Edmonton Alberta is making a similar product. I called them Yesterday for some info. The walls are $12.50 a squarefoot, the floors are roughly $10.00 and the roof, the guy said use normal trusses as our roof are 5x more. There is a local supplier I learned of who has done several builds near here, I will be contcting them to see full foundations and a full home. I would love to build a cabin out of this stuff.
623greenUser is Offline
13 Feb 2012 05:40 PM
Polycore is simply c studs. Nothing more. K-tect has proprietary structural steel studs and is much stronger. K-tect may span roofs up to 20 ft. Contact K-tect. They will provide you with all the information. By the way the eps does not support a flame and will off gases water vapor. No harmfull chemicals. Cradle-to-cradle assessed.
StyroHomeUser is Offline
13 Feb 2012 06:02 PM
Could you offer more information on these systems? https://plus.google.com/u/0/b/109426197816373894364/109426197816373894364/posts
zehbossUser is Offline
10 Mar 2012 02:24 AM
If anyone is interested I can show you how to get higher performance for lower cost in a DIY or contractor build alternative system.
Brian
ICF Solutions
Engineering, Designing, and Building Passive, Net Zero, Self-Heated, Self-Cooled, Self-Electrified, Low Cost Homes
Basic shell starting at R-50 Walls, R-80 Roof structures. for $30/square foot
(360) 529-9339
10 Mar 2012 11:32 AM
Sure, what's that ICF?
10 Mar 2012 09:25 PM
I typically recommend either an onsite DIY metal metal SIP system or an insulated ballast filled high mass gabion system. Both offer a lower cost to performance ratio than anything else I see out there and are more flexible in design.
Brian
ICF Solutions
(360) 529-9339
HHGreenBuildUser is Offline
05 Apr 2012 10:29 AM
We have recently finished the first K-tect home in Canada!
Check out the story >> http://www.ottawacitizen.com/homes/Showing+metal+their/6389447/story.html
Alfred
LarryTUser is Offline
Odabree
I havent been to this thread since 2010. Just saw your post from last fall asking where things stood with my use of it. Can't say I yet have experience but am continuing to move towards the goal. In 2010 I mentioned we had a few years off before we'd retire and build. Things look better today. Got my home in Virginia up for sale 1st of May. When it sells, we'll move to Santa Fe where I'll be close enough to monitor construction while I still work a few years. Still planning on using KAMA for the above ground two levels. Plan to break ground Spring '13. Still sold on the product in my mind
People Online People Online: Visitors Visitors: 180 Members Members: 0 Total Total: 180
