Thanks for your input, as always, it is very helpful.
If I understand you correctly and take into account our site, it seems to me the proposed solution would be:
- attach 2’ x 12’ and 2” thick XPS to exterior block, supported by lumber as needed
- XPS serves as form as well as slab-edge insulation, lumber taken off after pour
- protect exterior XPS with cement board (gravel parking, no paving)
This makes ‘construction’ sense and seems doable. But let me ask about a concern I have. Termites!
Termites were in part the reason why I chose to use the rigid insulation on the interior of the building foundation wall rather than exterior. I could be wrong, but I thought the risk might be less with the
interior XPS application. Also, the framer used
untreated lumber & no gasket between block and lumber for vertical framing around the 12x12 door (this only for the door framing, not for the sill which is treated with good quality gasket underneath).
I plan to treat the lumber with Timbor – but I’m not sure how well that protects, especially since the metal siding/trim is already on. And for that matter I don’t have an accurate picture on what the
real risk is from termites, and how rigid insulation may impact that risk. Am I building a well insulated structure that will require extensive reframing 15 yrs down the line? I hope not.
I’ve attached a close-up of the framing (from the interior) to show my area of concern. A small piece of XPS in the corner is not yet installed but I will add it. The top of slab will be two inches below the top of the interior XPS around the entire perimeter of the building.
How much increased risk is there from termites if I have an
exterior piece XPS (2’ wide, 2” thick) down in the ground and extending up to the top of slab (to provide a form and insulation)?
With the termite issue in mind, do you have any other comments/advice on construction?
Thanks!
