Posted By rpatterman on 15 Apr 2013 01:43 PM
If you are heating with electricity, why not a ductless mini-split at 2-3 times the efficency of electric resistance heating?
And how does the heat get into the radiant floor? I have had this same suggestion thrown at me a few times in my house planning. Don't get me wrong, the mini split ductless systems are great if heating the air is all you are after. But if you want the comfort of a radiant floor, I have not found too many manufacturers offering hot water production options to use them as your radiant water heat source.
One of the cool things about the radiant floor with water as a medium, is that it easilly opens the door for alternate means of heat collection such as a wood fired boiler or solar, and storage such as a large mass insulated water tank. Add heat source, pump and perhaps a heat exchanger and you are in buisness with very little energy required to collect the heat.
I guess another option for providing heat would be a heat recovery type hot water heater. The small A/C unit used by these hot water tanks probably won't meet your peak heating demand and the traditional element backup heaters would run, but it may meet a large portion of the average demand at increased efficiency. I havn't really looked into their specs yet though...
