With drainwater heat recovery (DWHR) it's as much about the showering performance as it is about the NPV on fuel savings. At buck-a-therm gas it's not saving much, but never running out of hot water is good for family harmony, eh? With a typical gas-fired tank heater + DWHR you can pretty much never run out of hot water with 1.5-2gpm low-flow showers. That's not necessarily always a good thing- I had to dial back the occupancy sensor time out on the bathroom lights to keep his showering times reasonable, but at least you'll never here the hollering from the less than comfortable spouse who steps into the shower after you.
If you're heating hot water with 20 cent electricity or $4/gallon heating oil the savings are pretty good. The people who REALLY make out with DWHR units are the folks with monster-gusher 6 side spray luxury showers, since it can save them the cost of an second or super-upsized hot water heater, as well the ~50% reduction in water heating fuel used for showers. In some homes showering accounts for less than 25% of all hot water use, but in homes with monster-gushers it's likely to be well over half.
EcoInnovation has a lower buy-direct price than the competition, but you can beat them fairly substantially on price/performance buying a competitor's product through
EFI (headquartered in Westboro, MA). EFI has liberal policies for opening up accounts (over the phone with a credit card works), which allows you to buy drainwater heat exchangers at their
listed wholesale price (plus shipping no handling charges or markups from their Wisconsin facility.) The competitor's 3" x 48" has been third party tested at 47.3% efficiency as listed on
NRCan's rebate eligibility list which is the same or better 47% manufacturers' stated efficiency of the TD348B (I guess that's about what you get out of a 3" x 48") but it is ~$115 less than the buy-direct price of the TD348B if you buy through EFI. Not big potatoes in the whole installed cost, but still a substantial fraction of the raw hardware cost.
I installed a DWHR unit a handful of years ago (a 4" x 48" PowerPipe) primarily for the showering performance factor on my combi HW/space-heating to allow continuous & simultaneous space heating & hot water calls without running short of either, and without having to crank up a high-output burner. It's performance was critical in making that possible, and it's definitely doing the trick.
