Posted By Bob I on 06 May 2013 08:08 AM
you're a lot better off using sheet foam on the exterior surface of the sheathed wall, where it will act as a thermal break. It will also help seal the assembly from air infiltration and warm up your wall so that your cavity insulation works better. If you go this route, you need to be careful about the thickness - you want enough so that moisture doesn't condense on the interior face of the sheathing.
That type of condensation has been a huge issue with houses built in the past 30 years, (leads to mold and rot) and is best addressed by paying attention to superinsulation techniques. the flash & batt technique you ask about is a like a bandaid on a broken leg.
Bob, Sheet foam on the outside of the house instead of Tyvek wrap?
How does sheet foam on the outside help "warm up the wall"?
So is 1/2" thick enough to avoid inner wall sheathing condensation?
I assume I'd need to tape seal the seams of the sheet foam? I've never paid much attention to the installation of it (and it seems to not be a choice used around here anymore, but you used to see it a lot) but how it is installed (attached to the wall sheathing)?
