if you can guarantee it a drain path
I agree with Ronmar - but be aware that the gravel acts as a filter and unless cleaned, all filters will eventually clog. So preventing surface water from getting underneath the slab is preferred over letting it get there and then draining it away. The latter is a good backup.
