Posted By DavidW on 21 Feb 2017 05:02 PM
I am looking to have new windows and siding installed at my home in Omaha NE(climate zone 5, and would also like to re-insulated as well. This is the process i am looking to do:
1. Remove and save siding/sheathing. (same thing on my home 3/4 plywood)
2. Remove old batt insulation.
3. Install plastic vapor vapor barrier against drywall between studs. (is this even necessary)
4. Install Roxul
5. Reinstall sheathing
6. block around windows with 1" nailers to make up for foam
7. Install 3/4" or 1" polyiso
8. Install windows and house wrap (need to figure out interier jamb extensions to make up for the foam)
9. Install siding
Please let me know if anything can be added/removed from this list.
Thanks-
With foil-faced foam on the exterior, do NOT install an interior side polyethylene vapor barrier, since any moisture that finds it way into the cavity can't leave quickly via vapor diffusion alone.
In zone 5, with as little as R5 of exterior foam you would meet the IRC prescriptives for being able to use interior latex paint, per Table R702.7.1 :
http://codes.iccsafe.org/app/book/content/2015-I-Codes/2015%20IRC%20HTML/Chapter%207.html
Polyiso needs to be derated a bit when it's on the cold side of the assembly, and R15 rock wool is going to need a bit more exterior R for dew point control than R13s, so 3/4" polyiso is out, but 1" (R6- derated to R5-R5.5 for dew point control in zone 5) should be fine.
While you have it open, take the time to caulk the wallboard to the studs inside every stud bay, seal the bottom plate to the subfloor, and seal the seam between any doubled up framing such as top plates, etc. using polyurethane caulk. (This goes pretty quickly if you invest in a powered caulking gun). Seal up all the electrical boxes electrical & plumbing penetrations of the framing & wallboard too. Some of this will be easier to do with can-foam than caulk. A square inch of air leakage into the cavity from the interior moves a heluva lot more moisture out to the sheathing in winter than vapor diffusion through latex paint on wallboard.
Trim the fit of the batts perfectly, no compressions, no voids, or it will not perform to it's rated R due to thermal bypass air currents/convection or the lower R of thin sections. A 10" bread knife works great for sculpting batts, but so do purpose-made batt knives.
Tape/caulk the seams of the new sheathing with the appropriate materials. (Polurethane caulk between the framing & sheathing on each sheet as it goes up works, but so does taping the seams and caulking the top & bottom edges.)
A critical factor to get right with the housewrap is to lap the window flashing properly to the housewrap. Unless you're replacing the windows this means the housewrap will probably have to go between the sheathing and foam layer, which is fine (a standard "innie" window mount where the glass is roughly co-planar with the sheathing rather than the siding.) When taking this approach it's better to use a crinkled rather than smooth housewrap (eg Tyvek DrainWrap), since it gives it a bit of capillary break, and a path for any bulk water to leave via gravity. The small amount of air leakage from that micro-gap isn't much of a thermal bypass, and will not measurably affect the the thermal performance of the asssembly.
