foam insulation on steel
Last Post 15 May 2007 08:19 PM by icfcontractor. 2 Replies.
sfairUser is Offline
15 May 2007 12:14 PM
Has anybody ever spray foamed a steel roof that was sitting on 2x4 purlins.  The steel was put on top of purlins instead of plywood and the owner wants to have it sprayfoamed on the underside of the steel to create a sealed attic.  The roof is a 9-12 slope, about 24 feet long from the peak to the soffit, with an attic built in.  It is going to be used as a concitions space and he wants it insulated on the underside of the steal.
shortlyUser is Offline
15 May 2007 12:59 PM
It'll work well as long as you spray ALL the interior steel that has a conductive path to the exterior - roof, purlins, beams, verticals - everything. Steel is such a good conductor that any left exposed will condense ("sweat") during cold weather.
A friend did exactly what you are describing with great results. ICF walls, 8/12 pitch steel roof on purlins with 3" of urethane over all the steel. In fact, all the framing is steel, no stinkin termite bait anywhere. The upstairs rooms are framed with steel studs and have batt fiberglass primarily for sound attenuation. The whole house - all 2800 square feet of it - is kept comfortable with a single 2 1/2 ton ac system, in Texas.
icfcontractorUser is Offline
Sfair,
One thing to check on is the adhesion factor on the foam you choose to use and make sure that the steel was not treated with a thin coat of oil to reduce corrosion. If it was then you will need to degrease it.
ICF Contractor
People Online People Online: Visitors Visitors: 144 Members Members: 0 Total Total: 144
