Another example concrete hip roof!
Last Post 15 Nov 2008 01:48 PM by icicle earth home. 43 Replies.
Page 1 of 3123 > >>
miamicanesUser is Offline
06 Jun 2007 03:10 PM
For anyone who's interested, the gallery on this site is just about the best, most graphic concrete-roof-porn I've found to date :-)
It's a builder in Hawaii. It's a single-family home built in Oahu.  Apparently, they've had quite a few visitors eager to see it as word has slowly gotten out... perhaps someone from this site has actually seen the house in person? Anyway, it's one more builder who gets to join the tiny elite group of ICF pioneers who've successfully built a real, honest to god concrete hip roof (as far as I know, Ian is the only one here who's actually done it himself and posted pictures to prove it).
Here's a sample pic to tease you: beautiful hips, cleaving valleys, (temporarily) bare (future) ridge beam, and all!
ContractorPeteUser is Offline
06 Jun 2007 11:07 PM
WOW cool job
contractorpete@gmail.com
VermonterUser is Offline
15 Jun 2007 12:58 AM
Incredible! I wonder if they had to use a special mix for the 4/12 pitch.
fuggyUser is Offline
26 Jun 2007 01:33 PM
We have been holding off building in Florida because this subject has bugged me for ages. How can I put a cotton-pickin wood roof on my ICF structure? And here you have a pic of someone doing it. Anybody has more info please send it to me!
fuggywater@hotmail.com put in the subject line "pitched ICF roof" please!
26 Jun 2007 01:51 PM
What kind of roofing is applied over the concrete? After all, it would be a bit of a challenge to nail asphalt shingles to it! :-)
Building house - what a way to spend retirement! It's done! We're living in it!
26 Jun 2007 01:54 PM
Thanks for the link. The website is beautiful. What do you think they put on top of their ICF Hip roof to keep out the elements? I've got hurricanes to worry about. I could just paint the ICF roof. I thought about laying tile on it but water would go through the grout. I hate to drill holes in it to attach anything...I don't know much about building, is there any kind of expensive cement I could use as the top layer on the roof that is waterproof?
amccartyUser is Offline
26 Jun 2007 02:05 PM
I have a question.
I would love to put a concrete roof on the house I intend to build.  But one thing has
always stumped me.
It appears that the concrete on the roof would have to be tied directly into the
concrete walls.  Wouldn't this create a thermal bridge?
How likely is it that the concrete on the roof would transfer heat/cold into the
walls make the thermal mass work against you?
Would insulation be necessary on top of the concreate?  Or is there special
ways to tie the wall to the roof that would eliminate the bridging?
Maybe I am way off base...  I would love to hear opinions.
Andy
KsCustomUser is Offline
26 Jun 2007 10:56 PM
Andy, good point. Any attempt to create a thermal break at the walls and support points weakens this type of system. Additionally, every manual I've seen on litedeck or Insuldeck call for monolithic pours, especially of intregal beams. I am not sure their system would qualify as monolithic. If it works, well, looks good anyway.
PatrickTUser is Offline
27 Jun 2007 09:49 AM
amccarty,
We are building with a flat concrete roof. I have asked this question here of 'slab isolation' and have not received much of any replies. I called my ICF block guys and Hambro. Again, not much could be stated. Finally I called the engineering dept in Hambro Canada div. They said this question comes up very seldom. I offered my solution of placing a 1/4" fiber glass sheet the width of the concrete core on the top prior to placing the steel joists. In addition, use 90 deg fiberglass Rebar to tie the wall to the slab. Since Hambro can be placed on wood framed walls, I see no reason the joists cound'nt sit on fiber glass sheet. certainly has a higher compression than wood.
Since we are using Radient heating, some heat will flow in to the wall system. But in our case, we will have 4 5/8" of foam on the outside and 2 5/8" on the inside. Heat loss into the walls still can/could be considered 'in side the thermal envelope'.
I'm just not sure what kind of heat loss I would face if I did nothing
Patrick T.
Ian with ICF BuildersUser is Offline
27 Jun 2007 10:01 AM
Most of the ICF floor systems such as the one pictured do offer a thermal break as they are foam.  No concrete is exposed on the inside of the thermal envelope.  Additionally, you can add more EPS or use a urethane foam on the underside....or on the top of the roof.
To seal the roof from water penetration, there are a myriad of options....a membrane, either liquid applied or sheet, metal, tile..
You can use an overlay, admixtures in the concrete and coatings, etc...to make the roof look like a composition, the finished look just depends on what you want, making the roof water tight is not tough.
Concrete as a roof structure as the one pictured is a viable alternative to wood frame, seems few people are willing to pay the premium for it.
Also, if design will allow, use the roof as a deck and make the roof flat...or with minimal pitch...a traffic overlay like grailcoat will offer sealing and a nice appealing deck surface.
27 Jun 2007 09:05 PM
Ian,
I guess the thermal envelope should be defined. If the roof slab is poured in contact with the ICF wall concrete, you typically have only 2.5" of foam seperating you from exposure in the walls. The idea idea of Lite deck/Panel deck is foam on the underside. The exposed concrete roof deck will pull or receive the heat from the ICF wall in winter and push heat to the ICF wall in summer.
Patrick T.
icfcontractorUser is Offline
27 Jun 2007 09:16 PM
We are staring a home in a couple of weeks. This home will 100 percent concrete. It will have ICF walls, the new Logix floor sytem for floors and roof. This will be all cast in place. It will have cantilevered decks and eaves. We will be using a combination of products to waterproof the roof. It will be a green roof so we will use a waterproofing admixture in the concrete, a poly urea top coat, and a drain mat under 6 inches of soil. It will have approx 9000 sqft under roof. If I could figure out how to post the PDF model I have I would.
ICF Contractor
27 Jun 2007 09:34 PM
ICFcontractor,
Now thats a big roof at 9000 sq-ft! I thought my 3400 sq-ft flat roof was big. What add mix you using? I've looked in to Zypex a bit and it's ava local.
Is the Logix system a foam form system needing shoring like Panel/Lite deck?
Patrick T.
27 Jun 2007 09:41 PM
Patrick, I agree, but considering the wood option, the ICF option offers more benefit, even though it may not be perfect.  I would also submit that the entire roof is storing heat or cold energy, but the transmittance of that energy through the EPS has to be lower than that of a generic roof structure.  Again, one could add more insulation such as the spray applied to either side.
Ian
27 Jun 2007 09:59 PM
icfcontractor,
Would the 6" of soil be an insulator?  Or conductor?
If dry, my guess is that it would be an excellent insulator and
be fairly effecient at keeping the concrete roof from catching the
brunt of the external temperatures.  But if it is wet...  does that
make adifference?
Andy
27 Jun 2007 10:00 PM
Posted By icfcontractor on 06/27/2007 9:16 PM
ICF Contractor
Please do post photos/pdf model.  I am looking to build a similar home.   passive solar concrete with cantilever decks/eaves.
27 Jun 2007 10:07 PM
icfcontractor
Sorry for my ignorance. I just googled for green roof and I was wonderfully informed.
Sounds cool.
Andy
27 Jun 2007 10:58 PM
Here is the model.
Attachment: demarest.JPG
seflpolystUser is Offline
28 Jun 2007 08:47 AM
we have re-built our own 45 year old cmu house after frances and jeanne destroyed our truss/plywood/shingle roof by adding 4' of icf walls on top of the old tie-beam and capping it with 2000 sf of flat and 3/12 pitch 12" insuldeck roofs. this includes 7' cantilevers and a 1600 sf roof-top patio for a 2500 sf 2 story new addition, which we have built this past year, all icf and insuldeck. our electric bills for the old house part dropped by 30%, the addition is still being finished.
we also have an all insuldeck floor/roof cmu development starting in the bahamas, some 40 buildings, including a 12000 sf club house with 2 story concrete hip roofs.
several earth-bermed insuldeck homes are just starting in louisiana.
anyone looking for pictures or cad/pdf details please email me and i'll gladly send you a cd.
nationwide wanted to raise our rates some 200% and then canceled us anyway because we are in florida, on the intracoastal.
we told them good bye and are now just insured for fire, liability and theft, at a fraction of the proposed nationwide hurricane rates.
let it blow.
seflpolyst@aol.com
insuldeckflorida@aol.com
28 Jun 2007 09:54 AM
Your model is fabulous!
Page 1 of 3123 > >>
Membership Membership: Latest New User Latest: frogman New Today New Today: 9 New Yesterday New Yesterday: 11 User Count Overall: 17343
People Online People Online: Visitors Visitors: 553 Members Members: 43 Total Total: 596
