flashing / parging / waterproofing...
Last Post 13 May 2009 11:32 AM by jamesmacdonald1. 6 Replies.
Joe_XUser is Offline
31 Dec 2007 11:45 PM
I am general contractor (somewhat against my will) on my two story with full basement ICF house.  Plan on Hardiboard horizontal siding on top of cultured stone "foundation" to just above grade.
Should I cut back my basement waterproofing to grade and cut some flashing into the foam to direct water over the basement waterproofing?
or will the cultured stone thinset / mesh base hold to the foam?
barkri12User is Offline
30 Apr 2009 11:59 PM
Concrete has small openings in it left behind from its drying process. Water evaporates in a process called Curing. It leaves behind very small holes called micro-pores. The micro-pores, separated by thin layers of concrete, can be easily broken into with enough force. So, like a sponge with holes, concrete's holes invite water to seek it's own level by entering the voids left from the drying process.
01 May 2009 10:23 AM
What type of below grade waterproofing are you using?
HoowoodUser is Offline
10 May 2009 05:30 AM
Posted By Joe_X on 12/31/2007 11:45 PM
Check here for the finest information´s
http://www.doerken.de/bvf-en/
Attachment: Wall Sealing.jpg
11 May 2009 08:01 AM
Drainage planes (Delta, Platon, etc), are in my opinion a better way to waterproof. Rather than relying only on stoping the water from getting into the wall and basement it does 3 things:
1. It primarily stops water as closed membrane
2. It prevents the build up of hydrostatic pressure directly against the wall
3. Any water that does get through membrane then has a large airspace to drain down and into the drainage pipe.
11 May 2009 10:17 AM
I had to tackle this same basic issue, but not exactly the same situation. Near the end of this thread I show what I did to shed water over the waterproof membrane. http://www.greenbuildingtalk.com/Forums/tabid/53/view/topic/forumid/4/postid/44303/Default.aspx
Take a look at it near the end to see a problem I had with the ICF foam to membrane transition and how I solved it. This won't work the same in your case but I think you'll be more aware of potential problems.
You might be able to lap the mesh for the stone over the membrane and build a mortar transition from the foam to the membrane. You'll want to fasten the mesh, or lath as the masons call it, for the stone to the ICF blocks with screws. It'll work good. You can take the stone all the way to soil, right?
Not that you asked about it but I'll get a picture in a day or two to show how I transitioned from Hardiplank siding to the stone. The mason who put up the stone was impressed.
Building house - what a way to spend retirement! It's done! We're living in it!
Check the following link:
http://www.buildingsciencecorp.com/resources/presentations/Dallas_Zero_Energy_House.pdf
It was for a project the Building Science Corporation worked on that used Durisol ICF, cultured stone and Hardie plank. The pdf is really long, but at the end, there are some really good detail/flashing ideas.
Membership Membership: Latest New User Latest: avid0g New Today New Today: 1 New Yesterday New Yesterday: 10 User Count Overall: 17366
People Online People Online: Visitors Visitors: 303 Members Members: 23 Total Total: 326
