I need some input on ICF choice for a home I'm designing.
I plan to spec for exterior a vertical siding, either panelized such as fiber cement panel (e.g. HardiPanel Sierra 8) or Roseburg Forest Products Breckinridge (sort of a T-1-11), or a real wood shiplap. (That's the look we want.) I'd like to know whether it matters to spec an ICF with embedded webs such as Nudura's or ones with surface webs.
Other background factors:
1. We're in an area with very limited ICF builders (only 2 reputable that I know of) and limited available forms. 2. One of the two builders recommended NOT using Nudura (i.e. embedded webs) because he says there is an additional hassle factor in haging panels correctly. He uses Nudura and there is good local support, so he's not saying this because he doesn't like the form—he just wouldn't want to hang panel siding on it. He likes EIFS for it, but the owners and design don't really call for a stucco look. 3. I would prefer to spec an ICF that both builders would use, in large part because I want to draw the house as precisely as possible TO the system, and not have to deal with dimensional changes necessitated by mid-stream form changes. AND I would like to get the bids to be as apples-to-apples as possible.
If the answer is, "It doesn't matter," then could you experienced pros tell me the best, most cost-effective hanging method? Furring strips? Screw types? Pre-drilling required? etc.
Also, I'd appreciate input on any other factors I need to consider.
Thanks in advance.
