Reward, Amvic, Logix, IntegraSpec or Nudura which ICF
Last Post 05 Jul 2013 04:16 PM by Roger R. 62 Replies.
woulfcc
| 06 Oct 2008 11:18 PM |
On average I have been pouring around 100 yd. of concrete a week for about 20 + years.
Thats in a lot of different forms, not just icfs but wood , pans, decks what ever.
I work commercial construction mostly and thats what I do for a living.
I say this not to beat my chest but to let you know where my opinion is based from. Do you actual work with the concrete or sell stuff? I am not selling any thing here And I am not looking for work.
I love icfs they are so easy on the crew that is doing the build. Every man in the field I have put icfs in their hands like the ease of the stacking and see how this is a real assume way to build. All icfs. Hands down are a better way to build. I have used a lot of blocks and am always willing to work with a icf any one of them.
The icf form that I will use hands down over any one out on the market is integraspeck. If you look at the whole build it just works faster and cheaper the any other form out their. I don't get into bashing any one here, keep building with icfs they are the way to go. I don't make a dime on any icf here not in the last year any way. I just work with them. So what I heard from Buddy was PIN ON! I you think just anyone of the street can just stack and pour icfs and get it right all the time well Good luck to you! This is not to say that a hand man is not able to use icfs ( they can) Just know that sometimes people don't know what they don't know. In concrete that is dangeres.....things do go bad, can you fix it. Do you know how? Stop all the stack and pour stuff , put the block in the hands of the pros out in the feild.
| Changing How the World BUILDS!<br>Green , Done , Easy<br>Woulf c.c. of Wisconsin |
EMM
| 08 Oct 2008 11:18 AM |
I am curious of the statment regarding the HIPS plastic is stronger than polypropolene? A quick search from me found that the Amvic pull-out strength of 198 lbs./sq. in. where IntegraSpec is at 156 lbs./sq. in. Also, when pouring Amvic is listed with the strongest strength test at 865 lbs./sq.ft.
Also, one thing people like about the polypropolene is that its recycled material in most cases, I am unaware if the same can be said of the HIPS plactic.
renangle,
renangle,
Your perception on the HIPS plastic used in IntegraSpec is inaccurate. HIPS used in IntegraSpec is made of 100% repro.
For people wandering what HIPS means, here it is H= High, I= Impact, P= Poly, S= Styrene.
What buddy means, IntegraSpec use HIPS in their form because it is highly compatible with the EPS used for the panels fusing both materials together when being mold which make a stronger form.
Greenblock use to have the same HIPS plastic a while back making it to be a strong form as well. I know because we use to install it in the 90’s
As for the concrete free fall, that is another myth. See the attached document. Since we started using Greenblock & now IntegraSpec, we always filled our walls straight up. By filling them, the concrete is always flowing down & not dropping down.
Think about it, if you go around in lift, there is at least 2 to 3 lift. If you don’t pay attention, your are increasing the risk of cold joints between the lifts which create a weakness in the wall & on top of that creating possible water seepage point in the walls. Water is lazy & it will take the easiest route. Now if you have a water problem in your ICF walls, how do you find the problem spot???? |
Attachment: Free Fall of Concrete.pdf
Aaron McKinney
| 08 Oct 2008 12:10 PM |
Guys; that's a good article. I would like to show that to every inspector that made us cut port holes because they were concerned about the height we were pouring from. I might like the idea of being able to pour in one lift, and I do like the idea of eliminating possible cold joints. I was taught to vibrate the lifts together, going through the most recent lift 1' into the lift underneath it to mix the concrete together, which as far as I know has worked well. I'm assuming that with all the weight from pouring in one shot it would allow you to not need to vibrate as much. Can you guys experienced in this give some more details?
Alton
| 08 Oct 2008 12:19 PM |
EMM,
I read the attachment about the Free Fall of Concrete. Very interesting. Of course, this is opposite of what I was taught in school many years ago. Hopefully, I am not too old to change my thinking about how concrete behaves.
When you say you always fill the walls straight up, do you mean that most of the concrete is placed at one point. If so, do you have to add more bracing to counteract the fluid pressures at that point? Do you use superplasticizers that make the concrete more fluid? Please elaborate. |
EMM
| 08 Oct 2008 02:37 PM |
Posted By Alton on 10/08/2008 12:19 PM
Alton,
In our area the concrete plants have a specialized ICF mix which includes a type 2 superplastisizer & pea stone. The mix usually arrives on site at a 6 to 7” slump which flow nicely in the walls. It gives us plenty of time to pour & align our walls. Of course I move around while filling up the walls in one pass.
Believe it or not, since 1992, I can truly count on one hand the number of blow outs that I had in 16 years in ICF contracting. The worst part is, it was due to stupidity or trials/testing. The biggest advantage in using HIPS plastic, it gives you time to react do to the fusion between the two materials (HIPS/ties & EPS panels). I.e. if you see the form buldge while pouring you have time to move the pump without getting an actual blow out.
Aaron,
It happens to us on some occasion that an inspector requested us to remove pieces of foam at the bottom of the walls to see the concrete consolidation & one every occasion it was nicely consolidated. I will use a vibrator is in lintels & walls when we are dealing with quite of bit of rebar. |
Buddy Newberry
| 08 Oct 2008 02:57 PM |
In regards to EMM's post and the attached article, this is a document I am quite familiar with and am very happy to see posted. As mentioned in a post before when pouring heights that are above the specified recommendations it is important that you are using a high-end ICF that you trust and feel comfortable with. The addition of more bracing is not required and additional vibration would be left up to the installer. This technique of pouring the walls full, eliminates cold joints and ensures a monolithic wall structure. The flowing of the concrete throughout the forms provides for better concrete consolidation, but this is not to say vibration is not needed or should be lessened. However, if your concrete has the right amount of additives and the slump is 6" or 7" you could choose to only vibrate in tight spots. This is not something I have attempted yet simply because I bought the vibrator...It hasn't failed me and I'm going to use it.
This way of pouring saves time and money in having the pump truck on site for two hours not five, and from what I have experienced it yields professional results with the elimination of added complications when pouring in lifts as EMM has pointed out.
EMM is exactly right in referring to my reference about HIPS plastic, I meant to say that the fusion of the HIPS with the Type 2 EPS creates a stronger mechanical bond between the two materials resulting in a strong form, which is one reason why I trust IntegraSpec. I trust that if there is weakness within the forms due to an installation error I will be able to recognize this point of weakness before a blow out and avoid it until the necessary strapping is applied. As well, I was unaware that HIPS was 100% repro, that is good to know. Buddy Newberry,
renangle
| 08 Oct 2008 03:45 PM |
EMM,
I appreciate the clarrification on the HIPS, though I don't really see how it is that much stronger than other products mentioned before. The pull out test mentioned earlier states that it IntegraSpec is not as strong as others and the strength test of Amvic still stands by itself as the strongest as far as I have read. I have yet to see the hard data on IntegraSpec's superior strength. The data regarding Amvic can be found on the ICF comparison chart from ICF Builder Magazine.
I believe that all we need to look back to the initial question Marc and Kem asked (before the information changed), "please explain the differences between the blocks based on fact and not emotion". It appears to me that Marc and Kem are inexperienced to the ICF industry and would like their question answered as it was intened. Many of the earlier posts did just that and with regards to the historical intend of this forum, one should always try to be objective. Some may promote one block or the other, but for their particular job, most seem to agree that they should use the block that their contractor/subcontractor advises. Also that service should be a factor.
There are many experienced professionals on this forum who can pour a wall to the top in one pass as well as other things that many on this forum would be uncertain of doing. Stating that doing a pour in one pass (no lifts) could get a novice that reads this forum and believes that ICF construction isn't very difficult in a lot of trouble.
renangle |
lkazanov2
| 08 Oct 2008 10:28 PM |
Guys,
What about quadlock? The system is elegant, allows you to position the ties where needed, and has very strong corner system? What do you all think??
renangle
| 09 Oct 2008 08:43 AM |
lkazanov2,
As a building system ICF can't be beat in my opinion. With regards to who's block is better you will find several different opinions especially here. If a person is looking to build, the smart money is to identify the ICF professionals in your area, discuss your project with them, the block they commend, and research it (them and the block). Service (from the distributer or builder) when buiding with ICF is typicallly very important, do they have bracing, can they help you find an architect/engineer with ICF experience (if needed), how many projects have they done, what do they bring to the table?
If I lived in Rockford, IL and the only distributor/installer/builder around recommend Brand X and could show me they know what they're tallking about, I would probably use them. If I had no support and was going to still build with ICF I personally would use a block system that is as simple as possible to use, thus one that doesn't have to be put together on the job site, as I would be concerned that perhaps I would miss something.
Again, they all work at the end of the day, we could go on forever debating who's best...Amvic, Reward, Logix, Nudura, IntegraSpec, Quadlock, Build Block, Eco Block, Arxx, etc, etc, etc...most people here would recommend talking with a professional in your area, research them and make the best informed opinion possible.
renangle |
EMM
| 09 Oct 2008 10:45 AM |
lkazanov2,
Doesn’t matter which ICF system you select. Knock down or pre-assemble. What is very important is for you do your homework & choose the best dealer/rep that will give you the best customer support possible. Class room course simply doesn’t cut it out. You need to be trained on site as every site are different. Anybody without pouring experience should NOT be left pouring a job by themselves no matter which ICF forms used.
Renangle,
If I am not mistaking the pull out test is perform on the fastening strip by inserting anchors (i.e. screws & then pulling them out) & not the overall forms strength. Obviously we are both bias & feel confident with our choice of ICF brand with very similar end result. |
Marc&Kem
| 09 Oct 2008 10:03 PM |
Wow, what great info.
I know we tend to drift away from the original question, but this has helped us realize there are more important things to consider than the type of block. For instance, the installer and support and what has me busting at the seams to learn is the best method for vibrating/pouring the wall. Thanks for elaborating on those areas, it has helped us understand why a installer with experience is the key.
Marc and Kemella |
Buddy Newberry
| 10 Oct 2008 11:22 AM |
Marc & Kem,
An experienced installer is the KEY!! I applaud you for conducting such extensive ICF research and for asking the right questions. Once you have decided on a ICF wallsystem it is important to decide on the right installer and ask them the right questions as well.
It is important to ask if they are a certified installer of the product, follow that with a call to the Head Office of the ICF and verify their certification, most often it will be on file, however you may have to ask the Distributor of record for verification depending on their system of operations. Next, the installer may be certified, but what projects has he done??? If you are planning on going to the roof trusses with ICF you may not want someone who is only experienced with foundation applications. This is not to say they couldn't do it, and you may want to give an honest hard working person a chance if you believe they could. Many certifications are all encompassing and only some operate on a tiered certification program ex. A= foundations, B= Residential, C= Commercial, D= Commercial/Industrial. It is important to know what type of license they are operating on. If it is all ecompassing find references to projects they have done, if it is a tiered certification the level they have will tell you if they are qualified and capable of constructing your project (references still recommended). As well, customer support and training are paramount in this process as well, and EMM is correct in saying that this type of construction CANNOT be taught in a hotel room or through a seminar, on site training is the only way to go and if your installer is of the right certification he can train you on site as well. I believe in the tiered system simply because there is a certain amount of trust already instilled within the certification that the customer can count on.
In terms of vibration techniques, most often this is up to the installer. Building inspectors will expect to see a vibrator on site during the pour and being used often to ensure proper concrete consolidation and the absence of voids. It is very important that when vibrating you stick your pencil vibrator (generally 1/2" to 1" vibrator) in the conrete cavity and then turn it on and pull it out. Do not stick the vibrator in the wall while it is turned on, this can and will create air pockets in your concrete and negate the purpose of vibration. In pulling the vibrator up out of the concrete the concrete moves in a downward direction and ensures proper compaction. Pushing the vibrator down into the concrete seperates and slightly lifts the concrete which could result in a negative outcome. I vibrate every 5 to 6 feet, pushing the pencil vibrator as deep into the wall as possible, turn it on and pull it out.
Buddy Newberry, |
DesignGreen
| 17 Oct 2008 08:39 PM |
I have worked with four out of the five you have mentioned here, but from a design standpoint. I would agree w/Buddy. An experienced installer is the key. An experienced installer can take a "so-so" block and make a good install out of it. They can take a good block and make a superb install. So the installer is key. I have designed several homes and have worked with several installers. There is one in your area (Knoxville) that has consistently provided me good results. I'm sure they would be glad to help or consult with you. |
ph3nom3nalICF
| 07 Nov 2008 11:48 AM |
There's always ARXX, Eco-Block & Polysteel as well to consider. Really it's just best to do your research and based on your requirements a suitable fit should easily be found. Each block has its own features. for example: ARXX - exposed strapping for direct attachment of ext and int finishes PolySteel - Tall wall applications for fast set up ECO-Block - Knock Down block for ease of core width expansion Just thought I would throw some other good blocks into the ring. All The Best |
Bob
| 14 Jun 2013 10:25 AM |
BuildBlock, Reward, Amvic, Logix, IntegraSpec or Nudura are all good block. Each manufacture has to have a little tweak to be able to say "Their block is the best"! After all by making fine adjustments to their own product is simply marketing and their way to say they are the best. What makes a block good is the ability to be user friendly and do the job. In turn will help speed the building process along without compromising the project's integrity. Good planning is the name of the tune. Thus a block having no right or left, or up or down will make the job go smoother. Additionally there are two schools of thoughts RE: web spacing. In using a 6" concrete cavity's 8" webs are a little easier to use a pencil 1" vibrator. BUT - the flip side is that it is sure nice to have 6" centers for the finish work. On closing, and this does not effect me, it would be really sweet if the manufacture would tell their distributors to give out pricing on a per square foot along with what they believe would be shipping costs to a site. Being upfront with this is the only way to go. Manufactures and distributors guard this as though it is a propriety top secret! One should educate new clients in the over all benefits of ICF's and have pricing up front and center. In the end all would benefit. ICF construction is the way to build. Regards, from a guy with no dog in the fight.
BrucePolycrete
| 14 Jun 2013 11:05 AM |
There are opinions and then there are facts. There is a lot of junk out there passing itself off as a code compliant ICF. You would be amazed to learn that some companies market "ICFs" that do not comply with ICC. Others whose names you might recognize are so inferior that they barely cross the bar. Read more here http://polycreteusa.blogspot.com/ |
Lbear
| 14 Jun 2013 10:40 PM |
Posted By BrucePolycrete on 14 Jun 2013 11:05 AM
I believe if you stick with the NAME BRAND ICF's, you are safe. The big players like Nudura, Fox, Amvic, Polycrete, etc. The problem is that some states only have a few professional ICF installers. These installers have their own familiar "favorite" ICF block and they stick with that block. When a customer approaches them with an ICF job and asks them to switch blocks, they usually will not or they will charge a higher fee in order to do so. So I pose the question to you: If a customer came up to you and wanted to build a home using a name brand block other than Polycrete, would you agree to it and would you charge a higher fee? |
Chris Johnson
| 15 Jun 2013 08:40 AM |
Lbear, to address your question. there are many many many many factors in pricing a project, not just the block itself. Each block has it's own nuances. some require finicky work in one respect and not in another and vice-a-versa on another. Things to consider when reviewing a project, that a lot of people miss, site access. I normally order full trailer loads, so, can a 53' truck fit into the site, if not, where am I staging and how long to move from some shopping center parking lot on a smaller flat bed to the site itself. example, if the truck can get right on site, 45 minutes and we have unloaded the entire truck. if I am shuttling block it has taken 4-5 hours to move it, there is extra costs involved in doing that. Reversible block is worth it's weight in gold...especially with newer guys on site, less head scratching as they stare at a block trying to figure out a left and right corner, laugh as you may, I use to see it all the time. A larger, reversible block does install quicker based how fast it can be moved on the site, or ease of movement/placement in the work area. As you get up higher, smaller blocks require an extra man moving around and passing block up to the man on the scaffold, as opposed to leaning larger blocks against the scaffold and pulling them up as needed. Smaller blocks are easier to handle while cutting (rip cuts) above and below windows. If you are working on regular scaffold say doing a tall wall application, moving the block up to the workers is pretty much the same with a zoom boom and chances are reversibility doesn't mean a lot at that point either. But the number one thing, if you are not using a professional ICF installer, is tech support. ICF has been around long enough that in the big areas where ICF is common it is not an issue, but in some of the smaller areas where it is not common, who is the tech support, where is the stock coming from. If you are doing one foundation, and need 3 more blocks, can you get them? How long? etc. If you have left overs (as you should, never order the exact amount, shit happens, bad cuts, someone stepped on one, etc) can you return it? So before you make the block decision, start with the installer, what is his preference, he will give you a better price for block he is familiar with, now if you are buying the block, ask all the questions, stock, needing more, need to return, etc. Tech Support, everyone has a 1-800 number, big deal, if you are a DIY'er, lets be honest, you need someone to come to site occasionally, not someone answering a phone 1000 miles away trying to solve your issue. FYI, Tech Support can be an installer who is familiar with your ICF, some manufacturers will 'contract' to installers to keep an eye on you. Don't go shopping on price, as the saying goes, you get what you pay for, sometimes you get lucky, but not always the best bang for your buck
sailawayrb
| 15 Jun 2013 01:21 PM |
As others have said, the choice of ICF system largely depends on your local combination of ICF system availability and associated contractor experience that will ensure a successful result. We suspect that block systems will soon become obsolete and will ultimately be replaced by vertical systems. There are already vertical systems available (e.g., TFSystems) that install much faster than block systems and can handle full 12' foot lifts with confidence. Vertical systems also offer other advantages such as ease of creating hydronic heated walls and allow having customized exterior and interior side R-values as required for specific building designs. |
TexasICF
| 16 Jun 2013 08:58 AM |
Posted By sailawayrb on 15 Jun 2013 01:21 PM
Do we? This is quite a statement and one that I must comment on. As far as I can tell the vertical systems remain collectively below a few % of the ICF market share. For these systems to be recognized as better they will need to begin capturing tens of millions of square feet of work per year not tens of thousands.
There is a lot of hype around the speed of these systems and their versatility. I will agree that they are much better than conventional construction. However, they have been around for several years and have not gained any significant momentum as far as I can tell. Regards. |
257 |
257 |
