Dino,
I'm curious why you are building the wall w/ vertical Insul-Deck? Is your procedure similar to tiltwall, where you pour on the ground and then lift into place? Unless you are wanting a specific exterior finish (such as exposed aggregate) that is difficult to achieve w/ a block, I would think it would be quicker to build with the block in the first place. Also, the greatest stress on a wall during tiltwall construction is when it is lifted into place (which generally requires a crane) and, consequently, more rebar is needed to strenthen the wall to withstand said stress.
jeff
