What are your thoughts on Nudura??? (good and bad)
rykertest
| 12 Jan 2009 11:11 AM |
I see a lot of posts on here, but few if any mention Nudura. They mention amvic, fox blocks, polysteel, arxx etc. They may be ok products but it seems to me (which may be the issue, to each his own kind of thing) that the only 3 to really consider are quadlock, reward and nudura. When I compare, they just seem to be the easier, more thought out and cost effective systems to use. I know this may ruffle some feathers, and that is not at all my intent so lets not get into a pissing match here. I guess to sum up my question; why is nudura not reccomended here, is there something wrong with the product I can't see? Maybe it is a regional thing? Is it that it is not advertised on here? Maybe it depends on if it is a DIY'er doing or vs. a gc?
Again please do not take this as me attacking "your" product, thats not what I am doing. I'm just trying to get some feedback on why nudura is not a presnce here or if there is any reason why that product should be avoided or praised.
Thanks.
thagreen
| 12 Jan 2009 12:28 PM |
Annother you might look into is integraspec. Good all around product! I find is one of the most versatile. Where are you located? |
GRickard
| 12 Jan 2009 12:42 PM |
When I was looking to build my house, I looked at Nudura, Amvic, and Integraspec. Only because thats what I knew of having local dealers. I contacted all three for pricing(I already had product info to compare).The Integraspec rep never even returned my call, so he was out right off the bat. Nudura and Amvic both seem to be great blocks with some unique features. When the pricing came in, I could build with Amvic for about $2k less. My guess is the Nudura dealer probably had more mark-up on his material. I'm just like everybody else and it all boiled down to the bottom dollar. I do have a neighbor that built with Nudura and was very happy with them.
Greg |
lkazanov2
| 12 Jan 2009 01:02 PM |
Just my few cents....I have looked and physically touched most blocks you mention. With regards to a design that would accommodate a block (vs panel) the block I think would be best. That is, a layout drawn to accommodate the pitch of the interlock and wall length to accommodate the linear dimension of the block to avoid untied joints. If the project requires multiple corners then I think panelized is best. Of the ones you mention I like quadlock. I have seen it, touched it, seen several projects, studied the manual. I think it is the best overall horizontal panel system. I believe they have the strongest corner available. However, for my individual project I am leaning to TF for the same reasons except that it is vertical. However, its corner needs external bracing. As I recall, every piece of the quadlock system including the EPS is molded in house but I could be wrong on this.
Nudura's interesting feature is that the internal plastic webs will lock with the block and above and below. This will add vertical stability and hopefully minimize the chance for vertical sepration during the pour. I believe Integraspec offers the same features...have you looked at it? Good luck with the project.
Leonard
rykertest
Posted By GRickard on 01/12/2009 12:42 PM When I was looking to build my house, I looked at Nudura, Amvic, and Integraspec. Only because thats what I knew of having local dealers. I contacted all three for pricing(I already had product info to compare).The Integraspec rep never even returned my call, so he was out right off the bat. Nudura and Amvic both seem to be great blocks with some unique features. When the pricing came in, I could build with Amvic for about $2k less. My guess is the Nudura dealer probably had more mark-up on his material. I'm just like everybody else and it all boiled down to the bottom dollar. I do have a neighbor that built with Nudura and was very happy with them.
Greg That's a legitimet reason, price is always a concern when building no matter the construction type. Glad to hear your neighbor is happy with his. I think no matter the system if it is done right that's the key. So if the price was even which would you of gone with? Was price the only reason you went with the other? Would the nudura guy not "price match"? If it were me and I saw a bid from a competitor I would rather get a sale and satisfied customer relationship than $2000.00
rykertest
| 12 Jan 2009 01:19 PM |
Posted By lkazanov2 on 01/12/2009 1:02 PM Just my few cents....I have looked and physically touched most blocks you mention. With regards to a design that would accommodate a block (vs panel) the block I think would be best. That is, a layout drawn to accommodate the pitch of the interlock and wall length to accommodate the linear dimension of the block to avoid untied joints. If the project requires multiple corners then I think panelized is best. Of the ones you mention I like quadlock. I have seen it, touched it, seen several projects, studied the manual. I think it is the best overall horizontal panel system. I believe they have the strongest corner available. However, for my individual project I am leaning to TF for the same reasons except that it is vertical. However, its corner needs external bracing. As I recall, every piece of the quadlock system including the EPS is molded in house but I could be wrong on this.
Leonard
Yes the locking block is a big benefit. What really impresses me so far is the support I get from nudura. I've not had any of the horror stories I hear about from other companies where they are great until they get the sale and them bye bye. I did try and obtain information from integraspec, but after being hung up on twice, and then never hearing back from the sales rep after leaving a voicemail, it just left a sour taste in my mouth so I didn't attempt to bring their product on board. It may be a great product don't get me wrong, I don't blame the product just the company. lol I have had good interaction with reward as well and quadlock was friendly. Whats sad but true is how, with so many good products on board, in my mind support is what can make or break a deal fo rme. I'm not made of money but if I get great support from one company and they cost a shade more, I still may pay more to oget the help I need and not just be left out to dry. You had a great post, thank you.
GRickard
| 12 Jan 2009 01:29 PM |
Rykertest, All things being even, at that point I was leaning toward the Nudura because I liked the size of the block and I had had more interaction with the Nudura rep. Before buying, I had several conversations with the Amvic rep. and could tell that I would get great custumer service from him (and I did). I don't want anyone to think the decision was made on price alone but these quotes weren't even close. As far as the price match goes, I am an industrial electrician for a large construction company and I wouldn't like it if a customer was to shop one of my bids, so I'm not going to shop someone else's bid. When I ask for a quote I will make it clear that I am pricing other distributors and even tell them who. If they want my business then they can give me their best price the first time. Hope I didn't step on anybodies toes there, that's just my view on a quote.
Greg |
rkflynn2
| 13 Jan 2009 11:56 AM |
Nudura has trained and certifed installers. |
rykertest
| 13 Jan 2009 01:25 PM |
Posted By GRickard on 01/12/2009 1:29 PM Rykertest, All things being even, at that point I was leaning toward the Nudura because I liked the size of the block and I had had more interaction with the Nudura rep. Before buying, I had several conversations with the Amvic rep. and could tell that I would get great custumer service from him (and I did). I don't want anyone to think the decision was made on price alone but these quotes weren't even close. As far as the price match goes, I am an industrial electrician for a large construction company and I wouldn't like it if a customer was to shop one of my bids, so I'm not going to shop someone else's bid. When I ask for a quote I will make it clear that I am pricing other distributors and even tell them who. If they want my business then they can give me their best price the first time. Hope I didn't step on anybodies toes there, that's just my view on a quote.
Greg Hey Greg thanks for the reply. As the bidder or bidee I consider comparing price as part of doing business. If I'm the homeowner lets say looking to build a home, I want a good product for a good price. If I want to use one certain guy for the job and he is a higher bid, well, it all depends on how much higher. a few hundred bucks won't make or break, but a few thousand or more needs serious evaluation. If I can't sell my product even at a slightly higher price maybe I'm not a good salesman or maybe the product isn't worth it. It really all depends on the buyer as they have so many varying ciscumstances it's comparing apples and doorknobs really.
ICFconstruction
| 13 Jan 2009 07:55 PM |
NUDURA is a great ICF we have used tens of thousand sf, but only one house in the past year. It was the best value for me in 2005 and 2006. Flippable is a plus, the folding is a plus but I think I get a straight wall easier with a rigid block. The only bad experience I had was with their 8" T. The 6" T is fine but the 8 has (had) a pieced together section that was weak.
Of the three your considering it is my favorite. I don't factor in support anymore, just product, price and to a lesser degree service. Whether we admit it or not price drives most projects.
NUDURA, and I suppose their attorney, will be quick to point out that they don't certify anyone to do anything. But they used to have a full two day seminar, the best I know. |
ICFconstruction
| 13 Jan 2009 07:59 PM |
One more thing, NUDURA makes their own forms and I think all their products. Try easy buck if you don't need a full wood buck. |
irnivek
| 14 Jan 2009 02:34 AM |
Leonard: I would have to disagree with your post that a build with multiple corners constitutes good reason for panelized systems. Fixed forms are king for multiple corner projects, both speed, waste, and prep and pourability. On a critical day, we might say "Fold flat/lay flat, pour flat." But we are rarely critical! Because that would be bad bad bad for the ICF industry I am told. All I can do is put my money where my mouth is and offer to do your job to prove it.
ICFConstruction: quote "I think I get a straight wall easier with a rigid block" I saw that! And when one knows better, don't they have to do better!? Or is pretty straight and pretty fast good enough?
Please note we stuffed 55 yds of 7 inch slump concrete in a 10 ft. high Nudura basement with 12 corners one time in about an hour and a half, braced exactly as we brace our normal forms;no scabs, no osb. Everyone was elated at quality and speed, however the trained eyes of our crew noticed the walls didn't sit quite as flat as our rigid block do, also the top of the wall conformed exactly to the undulations of the footer (done by other) due to the fact it is locked together vertically. One of the biggest things missing in the Nudura block is a rebar finger that allows stacking of bar without tying. (Stacking bar instead of bar side by side eases consolidation) Don't get me wrong, Nudura is great great great. Pretty handy when you cart them around on open trailers, it stacks just as fast, and Blue is my favourite. Dan Hilty please don't punch me out this time at WOC, ok?
Kevin Schilthuis Blue 80 Construction www.icfinstall.com straighter walls, faster |
lkazanov2
| 14 Jan 2009 09:32 PM |
Kevin,
I think Nudura is a good block. I have seen it, touched it, and explored its use. Like I said before if the house is drawn for a block (even with multiple corners) block makes sense. The flexibility of Quadlock to provide a strong corner and to allow you to place ties any where you wish is elegant. TF system's design could care less about wall length with regards to the block interlock pitch (quadlock prefers a 2" incement in the walls). I am fairly certain that if panelized was such a bad idea then the market would hasten their demise. Yet I see that quadlock is actually one of the "older" manufacturers around.
Thanks for your comments...if the bank pulls through I will start a blog website of the project.
Leonard
Chirp Frog
| 19 Jan 2009 03:32 PM |
Amvic would make a great choice because of price point and they continue to upgrade there product line. Those who have seen the days of no corner forms,brickledge forms, flooring systems, know the importance of these upgrades. Amvic has been progressive when it comes to this. Their corporate staff is also very supportive and knowledgeable .Nudura and Buildbock are both newer players to the market. With this said, both have shown that they are viable players in this rapidly changing field. Your choice will depend on many personal factors which go far beyond the performance of the above mentioned companies products . Keep during your do diligence and your obtained knowledge ,along with lifes experiences, will provide you with your product choice. |
GreginAlaska
| 14 Feb 2009 11:49 PM |
I had a designer draw up an ICF walled house with a monolithic dome roof. He, and the engineer he uses, went out and studied the different types of ICF forms out there. They decided to specify Nudura. I live in Alaska and they don't have a dealer here, I emailed the company to see if it is possible to get them shipped here. They didn't answer the email. I then called tham and they said no problem. I got the pdf files of the construction and engineering prints and emailed them for an estimate, no answer. I emailed a couple of more times and finally they said they were sending them to a distributer that would work with me. Got nothing from that company. Called them again and said they would make sure I get the info I need...10 months later I haven't heard a thing from them. They might make good forms, but, from my perspective, their business practices stink. Needless to say, I won't be using them.
JinMTVT
| 15 Feb 2009 10:41 AM |
I can only recommend the product that i have worked with ( once..personal house..first timer ) wich is Quad Lock. But i have seen up close 2 houses that were built with Nudura, and one is of a friend ( very big house.. 85' by 50' )
I also had quotes from QL, Nudura, Integra, Arxx and Izobest.
Izobest had the best price at first...beat all others by 3-4000$ on my project ( on ~40K$ buy) IT is an all local manufacturer ( quebec ), but i am happy i didn't use their blocks for 1 reason now, as i've seen and compare their foam ....i'd say around half quality/density to QL
Integra spec was in price, but the seller was bit "rough" for me, already trying to have me change stuff before we actually commit to anything. Again i have seen their products in hands afterward. ..and i don't understand how anyone can use that stuff.. ( sorry for the integra guys .... but i can't lie ) their foam is very cheap ( feels..and peels offf quite easily ) and their clips are so looose in the panels when slided, that i was astonished they let out a product with that big of tolerances ... the ties are also of bad plastic quality ..could break one off easily with hand while the QL one were totally unbreakable unless u cut ot notch them seriously
Nudura was not in price for my project.. 2-3000$ more than QL + QL offered me alot more stuff ( accessories ) + their documentation is very good ( since i all diy ..needed as much info as possible ) their engineer in BC was very helpfull on every occasion i discussed problems with him and the mudilarity of their product has a value that can't be priced ...
One thing guys, when i started my project... i had the feeling that QL was not recommended here, but now it seems to have moved up in "rank" ...what hapenned ? I have just built a 10K sq.ft. of wall house..with 40' of block heigh with very minimum bracing ( all interior ..wood ..some exterior for basement ) and 0 blowout ( well 1..but we had forgot to install the ties ...so not block fault ) the layout was labour extensive.but it was easy
What surprises me with most other blocks, is the lack of "material" between the blocks what holds the blocks from "stripping" and opening out ?
in QL system, the blocks aren't hold on themselves..leaving on the 'foam" to create a resistance when pouring the ties are what makes it strong ... i believe that this is a better design than only relying on the foam for side loading between the blocks neway
so the big house that was built near here with Nudura didn't have much problems, and it was in hand of a first timer ... they had 2-3 blowouts..only 1 serious and they used alot of bracing from what i can remember
Bruce
| 15 Feb 2009 05:31 PM |
JinMTVT,
I was impressed with the way QL looked and I've taken their installer class. Like you, I plan to DIY a house. Then I started looking ahead to installation of drywall. How hard is it to hit that relatively small square tie that isn't continuously vertical through the form like other forms are? I know they make a form with continuous ties, but I'm not sure what that will do to pricing. Of course they wouldn't tell me a price per component. Not sure why they want to keep it a secret.
QL says to pour lifts of three to four feet. Integraspec says to pour ten foot lifts. That leads me to believe Integraspec is stronger. Of course they temper that with not being able to fully fill both sides of window and door openings.
Then there is the engineering. Nudura has extensive engineering tables. While QL's engineering tables aren't nearly as robust as some of the others. Integraspec's tables are pretty good as well.
All the forms have advantages and disadvantages. |
SoCalScott
| 15 Feb 2009 09:48 PM |
Wall lengths - no matter what type of ICF you are using (block, panel, vertical, ect.) wall length dimensions determine if you are going to have vertical seams, which is why ICFs are user freindly in that they are easy to CUT. Very rarely is an architect goin to be able to make walls lengths fit onto specific increments so that you avoid vertical joints. So whether you have 8", 6", or are going vertical, at some point you will need to cut your forms (that is if yo uwant all of your studs to lign up vertically throughout the wall). There are so many other variables that an architect takes into consideration when designing a home/building that they rarely care about vertical joints.
Pour lifts. 3/4' vs. 10' - The error comes in the definition of "lift". All ICF companies (that I know of) recommend stacking the forms to a height of 10 - 12' and then pouring the wall in consecutive 3'-4' "lifts" per code. So the comparison being made above is based on a faulty premise.
Bracing - amount of bracing is more of a direct correlation to the project and the user, not the brand of ICF. Most ICF bracing systems are recommended to be used on one side of the wall and 5' to 6' OC. Any additional bracing used is either because of the installer wanting to be "extra careful", or because there are short walls / lots of corners or because they are bracing the back side of a t-wall, etc. to say that a certain ICF needs to be braced more than others, or that one doesn't need to be braced much of others, again isn't generally true.
Bruce
| 16 Feb 2009 06:15 AM |
SoCalScott said, “Pour lifts. 3/4' vs. 10' - The error comes in the definition of "lift". All ICF companies (that I know of) recommend stacking the forms to a height of 10 - 12' and then pouring the wall in consecutive 3'-4' "lifts" per code. So the comparison being made above is based on a faulty premise.”
This is from the Integraspec engineering manual page 3.
• Pour Height ______________________________ Up to 10 ft., 3.1 m Continuous Pour
This is from the Quad Lock Concrete mix and placement technical bulletin.
Height of Lifts: Always start with a maximum 2-3’ lift (a60-90cm) at the bottom of the wall. If this is your first pour, stick with 2’ (60cm) lifts for the whole job. As you gain experience with ICF pours, subsequent lifts can increase to 3-4’ (90-120cm).
We use IRC2003. I don’t find a lift height in that code. Where are you finding a code requirement for the lift height? |
roch
| 16 Feb 2009 03:40 PM |
any of you guys ever used Eco block |
180 |
180 |
