Tyvek over ICF
Last Post 04 Mar 2009 09:24 AM by hugh jones. 12 Replies.
Boontucky-girlUser is Offline
02 Mar 2009 10:40 AM
If you had to Tyvek or housewrap over ICF, how would you do it? I've talked to a few hardie siding contractors. A couple of them said it needs to have housewrap uner it. I don't think Tyvek over ICF is required, but if I have to put it up, I don't think it will hurt either.
So how could it be done? Stapled onto the foam?
02 Mar 2009 11:12 AM
If your ICFs have plastic bridging, I would use button tab nails driven into the bridging. This works very well for us. However, if you have metal bridging, you will have to use screws.
Wes Shelby
Design Systems Group
Murray KY
wandr@ainweb.net
02 Mar 2009 12:42 PM
We require it in CA. Usually use anything to hold it in place until the siding goes up, could be anything with a wide head such as a roofing nail into the foam.
Chris Johnson - Pro ICF
Napa, CA
Come for the wine, Stay for the ICF work
arkie6User is Online
02 Mar 2009 01:57 PM
I would think that the standard foam board nails with the plastic button heads and ring shanks would work just fine if driven into the plastic web pads.
02 Mar 2009 02:03 PM
02 Mar 2009 05:11 PM
Arkie6,
Sorry, button tab is a common (colloquial) term of 'plastic cap' nails.
Wes Shelby
Murray KY
wandr@ainweb.net
ICFconstructionUser is Online
02 Mar 2009 07:50 PM
Why would you put house wrap on ICFs?
02 Mar 2009 08:33 PM
Because some municipalities won't let you go without
Napa, CA
03 Mar 2009 05:48 AM
As I get older, I get more cautious. Tyvek is relatively inexpensive to purchase and easy to install. It adds an extra layer of insurance against air and water infiltration, and I'll take that trade off every time.
Wes Shelby
Murray KY
wandr@ainweb.net
Buddy NewberryUser is Offline
03 Mar 2009 10:20 AM
House wrap is not needed on ICF's.
In order to prove this, the ICF in question must have undergone Permeance Testing that was approved and accepted by the ICC in stating that house wrap and vapor barrier are not needed on the Wall System. If the ICF has completed this testing and it has been accepted, this documentation can be presented to your local building official. In order to obtain this information I would suggest asking the local Distributor or going directly to the manufacturer.
Buddy,
walltechUser is Offline
04 Mar 2009 06:55 AM
I agree with Buddy, many manufactures have this testing and could convince your BI that its not needed. I believe if you put the wrap on your going to start missing your fastening ties and have continual siding issues.
p.s. Chris J, your manufacture has this test also.
Dave
04 Mar 2009 08:56 AM
Unfortunately 1 out of 50 states uses a different code than the rest of the country.
What is ....
Come on, play Jeopardy with me (Even though a Canadian is the host you can still play...)
Napa, CA
hugh jonesUser is Offline
There's a reason the east coast refers to it as the LEFT COAST!!!!
Membership Membership: Latest New User Latest: HoumaMan New Today New Today: 6 New Yesterday New Yesterday: 10 User Count Overall: 17371
People Online People Online: Visitors Visitors: 558 Members Members: 36 Total Total: 594
