Posted By richm on 08/13/2009 11:11 PM
The mold "experts" (who are certified remediators) told me that household bleach will NOT kill mold spores. I remember from college days in Microbiology and from working in a county health dept. that the experts are correct.
From the CDC website:
http://www.cdc.gov/mold/faqs.htm
"Mold growth can be removed from hard surfaces with commercial products, soap and water, or a
bleach solution of no more than 1 cup of bleach in 1 gallon of water."
Article about some research at National Jewish Medical and Research Center. They found that bleach not only killed the mold spores but made the killed spores less allergenic.
http://www.medicalnewstoday.com/articles/31076.php
"The researchers grew the common fungus Aspergillus fumigatus on
building materials for two weeks, and then sprayed some with a dilute
household bleach solution (1:16 bleach to water), some with Tilex� Mold
& Mildew Remover, a cleaning product containing both bleach and
detergent, and others only with distilled water as a control. They then
compared the viability and the allergenicity of the treated and
untreated mold.
The researchers found that the use of the dilute bleach solution killed
the A. fumigatus spores. When viewed using an electron microscope, the
treated fungal spores appeared smaller, and lacked the surface
structures present on healthy spores. In addition, surface allergens
were no longer detected by ELISA antibody-binding assays, suggesting
that the spores were no longer allergenic."
In the interest of disclosure the research was sponsored by Clorox.
On the other hand you will find websites of those who make a living fighting mold saying that bleach doesn't work.
The only permanent solution is clean off the mold and prevent the recurrence of the heat and humidity that allowed the mold to grow in the first place.
