2.5# or 3.4# metal lath for traditional stucco
Last Post 18 Aug 2009 12:04 PM by Jerry Coombs. 8 Replies.
benoUser is Offline
14 Aug 2009 10:22 PM
Hi all,
I wonder which metal lath should I use with 3 coat cement stucco: 2.5 or 3.4 lbs/sq.yd over Nudura?
On the web I saw the recommendation to use 3.4# metal lath but at the local store they told me to use 2.5#. What is the right answer?
Many thanks,
Beno
rykertestUser is Offline
15 Aug 2009 08:14 AM
Have you ever considered this? It works GREAT with icf.
http://en.wikipedia.org/wiki/Exterior_Insulation_Finishing_System
But sorry I can't answer your question.
astroUser is Offline
15 Aug 2009 02:04 PM
i would use the 3.4lb the 2.5 is for tile floor mudjobs, or so i have been told
ICFARXXUser is Offline
16 Aug 2009 11:51 AM
Make sure it is the dimple lath
16 Aug 2009 12:34 PM
Dimple lath is the same as self-furring, right?
benoUser is Offline
17 Aug 2009 08:33 AM
Dimpled raised lath:
http://www.dietrichindustries.com/products/pdf/213_DMF07.PDF
V-Groove raises lath:
http://www.dietrichindustries.com/products/pdf/214_DMF07.PDF
Which one to choose?
Beno
benoUser is Offline
17 Aug 2009 08:35 AM
Also, should I choose Paper-Backed Offset Option? I thought to install to layers of felt under the lath.
17 Aug 2009 10:28 PM
You should put paper behind it. Call Dryvit they have a paper that meets the building codes. Tar paper does not meet code in some areas.
It is the same as self furring
Jerry D. Coombs, PEUser is Offline
Here is some good background information. Real "Stucco" is defined in ASTM C 1328. It defines the properties etc. of the cement. ASTM C 1063 covers the installation of lathing and furring. That one should give you some good pointers. Then ASTM C 926 covers the application.
Jerry D. Coombs, P.E.
Coombs Engineering Services
jcoombs@coombsengineering.com
Membership Membership: Latest New User Latest: Likewood2 New Today New Today: 3 New Yesterday New Yesterday: 7 User Count Overall: 17358
People Online People Online: Visitors Visitors: 448 Members Members: 41 Total Total: 489
