I am building my own house using ICF. The engineer has produced all sorts of specifications and I have done the Nudura course but there are still a few questions.
The engineer has specified the spacing of the starter bars within the foundations and the grade of bar to use. My question is whether you should start with a bar in the corner or do you set them out so that you have an even “space” at each end of the foundation? Does it matter?
Thanks very much.
Andrew
