judas
13 Nov 2010 08:47 PM |
i am wondering where the manufacturers of these ICFs are i would like to stay near to maine if possible but for future reference for anyone who passes this way .. listing the ones i found.. so far will add/edit please add them in and if the address is the corp headquarters and thier manufaturing facilitys are else where please correct :)
amvic buiding sys toronto ON Can also found a pacific in nevada
horizon insulated system --website dead--
IntegraSpec Phil-Insul Corporation kingston ON CAN
Lite Form Technologies SOUTH SIOUX CITY, NE usa
Quad-Lock Building Systems surry BC can reward wall sys omaha NE usa
greenblocks kudos to the easy to find info to plants and warehouse and corprate HQ locale jerome ID usa post falls ID usa mexacali mexico ("coming soon") colorado city CO usa becker MN usa nixa MO usa orlando FL usa boston MA usa
ECO block Cobourg, ON
build block Oklahoma City, OK usa
A-ONE Forms, manufactured and distributed by Tasler, Inc., Webster City, Iowa usa
ps i am also lookin at waffle wall(it seems engineered not jut a wall with foam boards around it) and icf floors and SIP roof. preliminary ofcourse
dmaceld
13 Nov 2010 09:50 PM |
Posted By judas on 13 Nov 2010 08:47 PM
Many, if not most, ICF mfrs use contract molders all over the country. Finding out who the actual molder is, and where they are located, for a particular brand may be problematic. Buildblock shows a plant in West Brookfield, MA, but doesn't say who it is. |
Even a retired engineer can build a house successfully w/ GBT help! |
galnar
14 Nov 2010 01:51 AM |
My Amvic blocks came from Diversified Plastics in Nixa, MO. |
judas
15 Nov 2010 12:25 AM |
ps i was researching leed is why i ask .. besides there is transport costs. .. but thanks all |
ICFconstruction
15 Nov 2010 08:13 PM |
I think all but Nudura are contract moulded. But I don't think there is anything wrong with that, if anything it promotes competition. I have visited three moulders and they made at least a dozen brands between them. I was impressed by each of them. |
Brad Kvanbek - ICFconstruction.net |
pjf
15 Nov 2010 08:17 PM |
integraspec makes there own block
BrucePolycrete
16 Nov 2010 01:23 AM |
Polycrete uses no contract molders. All Polycrete Big Block ICFs are made on proprietary Polycrete machines. They have to be, as no one else can mold EPS around the .16" steel wire mesh. Manufacturing plant is in Trois Rivieres, Quebec, halfway between Montreal and Quebec City on the St. Lawrence. |
renangle
16 Nov 2010 07:57 AM |
Okay, to make this slightly easier I would recommend checking out the following link or pdf file. It seems to cover most of the locations of ICF manufacturing facilities. http://www.icfmag.com/documents/ICF_COMP_CHART/ICF_Comp_Chart.pdf renangle |
ICFconstruction
16 Nov 2010 08:33 AM |
Judas, I would not worry about where your ICFs are made. The location of your contractor and distributor are more important. |
BrucePolycrete
16 Nov 2010 08:58 AM |
He's trying to calculate the transport distance for LEED points, but I have heard that it's not possible for EPS, as you cannot trace the raw materials (oil) to a specific source. With Polycrete, we can at least trace the steel component to the mill where it was recycled. |
TexasICF
16 Nov 2010 10:01 AM |
Bruce, If he's looking for LEED points he's wasting his time but it's at a much higher level than bead/oil raw materials. He needs to read LEED 5.1 and 5.2 carefully... these two points are available based on weight and are awarded (with rare exception of use of cost) based on the typical slab weight % of buiding (locally sourced concrete) and ICF wall installed weight % of building (locally sourced concrete). There's been a great focus on the 500 miles in the industry and inside 500 miles is great in the spirit of LEED but it's not going to get you anyadditional LEED points. Regards. |
BrucePolycrete
16 Nov 2010 10:16 AM |
If I understand correctly, the EPS can contribute to LEED 5.1 but not to 5.2. Can someone confirm? |
TexasICF
16 Nov 2010 11:03 AM |
Bruce, I will let someone else comment. However, what i was saying was that EPS can contribute to either or both 5.1 or 5.2. The issue is since the points are awarded based on weight of building components utilized in the building (e.g: steel, tile, sheetrock, wood, CMU, concrete, ICF, etc., etc. i recall that furniture may be excluded) the ICF is such as small percentage of the weight and the concrete of the slab and concrete of the ICF are so high that it really doesn't make any difference. Also, the target weights for percentage of the building for 5.1 and 5.2 are so low (like 20% and then an additional 10% if I recal correctly for each point respectively) that you might almost get there with the slab alone on a typcial building. Regards. |
Buddy Newberry
18 Nov 2010 10:43 AM |
IntegraSpec ICF's US and CDN manufacturing facilities are in the following locations:
Kansas City, KS
Reno, NV
Uxbridge, MA
Decatur, AL
Plymouth, WI
Quebec City, QC
Montreal, QC |
judas
20 Nov 2010 12:50 PM |
cool i will read the regs closely when it seems interesting again. i am trying to determine if its actually any real benefit to LEED. i of course dont mean building local(putting local manufacturers to work and not burning fuel to transport cross country/world . i think LEED is a interesting but misguided attempt i would rather have/support US canadian reclaimed wood or managed forest than plantation stewarded forests in boliva where there use to be jungle or where the bamboo is stripped in china when its not even mature but i am heading off on a rant lol there is a dragon cement plant 5~10 miles away and a coal co-generation plant ~93 miles away , dont get exited its co generates for a paper mill not residential. but if i dont pay X amount to get LEED i will be in the spirit of it and keep records of everything major.... but i still like the idea of the ICFs loaded into purchased containers that ya see near ports cheap (ie boston) loaded prefered on trains and sent to my area and dropped in my site and used for storage afterwards. reclaimed barn wood and other stuff bike/small tractor in the off season . organic garden storage you name it and a big thanks to all that posted locations of manufaturers |
