I know there was a discussion about tapering the inside of window openings to reduce the tunnel effect. The design offered was a sub-buck in a much larger opening. What about something more direct? Here's a drawing of an idea I had. I would only do the sides, with a flat top and bottom. The problems I see would be that the angled buck would have to be fairly precise, and would be tricky to secure. I'd fasten the angled piece and the straight piece together, and then insert it into the opening in the foam. The inner wall of the ICF would be trimmed with a hand saw, using the angled buck as a guide. Temporary cross braces would be cut to match the angle. Screws on the inside of the angled buck would anchor it to the concrete. The window opening is sized for a typical 6-9/16" window return, but the 4-9/16" could be done with different dimensions.
Do you think this could work? See any problems holding it in place during the pour? The method with the larger opening and the sub-buck looks poorly insulated to me, and uses a lot more lumber.
