ICF & InsulDeck Details
Last Post 15 May 2012 03:28 PM by Chris Johnson. 10 Replies.
13 May 2012 02:27 AM
Here is an InsulDeck and ICF transition detail. This is for the 2nd floor area of the home. I had some questions and needed some input. This will all be engineered in the end but we are trying to get the details and elevations done so we can then turn in a set of plans to have them engineered.
As it stands right now the concrete beam is probably much larger than required for the spans we have anyway. 12' from column to column. Per foot loading on this beam varies (same 24" depth everywhere) but the max. load it will be supporting is the Master Suite extension, but in that case, column to column span is only 8'.
My main concern was the execution of form-work and reinforcing placement of this beam and its connection to the top of the round 12" concrete column with the column being wider than the beam.
The 24" deep concrete beam could not exceed 8" in depth (if centered on the column) and could only be a max. of 10" wide (if off-centered) in order to maintain the 2" inset reveal from the face of the column that we need for the detailing.
Any input or advice?
InsulDeckICFDetail
Attachment: FloorWallICFDetail.pdf
13 May 2012 11:53 AM
Based on your drawing, a steel beam could also be feasible there as well
13 May 2012 05:48 PM
Posted By Chris Johnson on 13 May 2012 11:53 AM
Which would be easier and less costly. the steel beam or concrete?
13 May 2012 07:29 PM
That's a loaded question
Who's doing the work? If you, the concrete beam is cheaper
The steel beam is easier, it's a simple set it and forget it, it's done
13 May 2012 11:08 PM
Posted By Chris Johnson on 13 May 2012 07:29 PM
The work will be done by a contractor.
How would the steel beam be anchored down to the 2nd story InsulDeck floor and column?
insuldeckfloridaUser is Offline
14 May 2012 09:06 AM
lbear
if you email me a set of plans i'll be glad to comment....
14 May 2012 05:59 PM
Posted By insuldeckflorida on 14 May 2012 09:06 AM
lbear
OK, I emailed over the plans. Thanks
14 May 2012 09:45 PM
Peter is the expert in this, but to answer what you asked me
There will be a bracket that goes in the columns to hold the beam
The beam will have some rebar detail that is welded to the top flange and run into the insuldeck to secure it
The engineer will make all the connection details
15 May 2012 12:18 AM
Posted By Chris Johnson on 14 May 2012 09:45 PM
So which would YOU use, the steel beam or concrete? Which is stronger?
I assume that the steel beam can have concrete touching it as it is coated, right?
15 May 2012 03:12 PM
you can have a flush or drop down concrete beam, or a steel beam enclosed in the floor, partially dropped down or fully below. matter of choice, price, architecural need, availabilty of material and installers.
if not needed as steel i-beam for span or load reasons, i prefer a formed concrete beam, integrated into the insuldeck floor. as there likely will be a concrete forming crew doing the insuldeck, its easy to form a concrete beam.
same materials and tools, a little plywood and some 2x4,s... concrete pump will do the heavy work, no crane needed to hoist anything in place. no need for special connections or imbeds, or welding etc. just rebar, as with the walls.
Haha, I'm an installer, I would do the concrete beam, I make money building the form, fabricating the stirups, putting all the pieces together, more so than plopping the steel beam in place and it's done.
Each has there application and place, in your application I would use a concrete beam as Peter tells you above, no crane needed. On a commercial project there is usually more than one need for a crane so they are more readily available and cost is not as critical as it is in a housing project.
People Online People Online: Visitors Visitors: 199 Members Members: 0 Total Total: 199
