Can anyone recommend a general spray adhesive that is okay to use to improve the bonding of a peel-and-stick membrane to ICF? The manufacturer's recommended spray adhesive isn't available to us locally and we need to install the membrane this weekend. I'm looking for an equivalent product that I can buy at the local big-box store.
We need the adhesive to improve the bonding of the membrane because it's an application where the ICF has either been exposed to the elements for 8 years above grade or has been below grade (behind a dimple membrane) and is dirty. We've already applied the membrane in a few places and it isn't adhering that great despite prepping the surface to remove as much dirt as possible. Temperature conditions were optimal during the application.
