Posted By icfbound on 27 Aug 2017 10:35 PM
What I-beam? Bent nails?
Normally place L-bolts at top of wall @ 4' OC. Then drill holes in sill plate and use 3" square foundation washers and nuts to fasten. Need to place the L-bolts so don't interfere with trusses and catch all the ends of sill plate lumber.
The I-beam on which the joists are sitting. Bent nails are can be seen here: https://i.stack.imgur.com/J4c3U.jpg
I know about the sill plate under the trusses but not sure about one on top of the I beam
