Hello Adam.
We built custom stick homes starting in the late 60's. We built them as good and tight as possible with pretty much every insulation method mentioned here. In that period we didn't even have house wrap so we used felt paper to help reduce any air leaks. A vapor barrier was sheet plastic. Ahhh.... the bad old days.
We started using EPS SIPs in 1981. Poly SIPs were available but we couldn't bring ourselves to use them because of the CFC blowing agent being used at that time. Since CFC's have been taken out, we use Poly SIPs exclusively.
Starting in 1997, Thermocore of Indiana supplied the Poly SIPs for us until about 2002 when a plant was built here in Missouri. Thermocore of Missouri is our main supplier unless one of our jobs is closer to the Indiana plant. The two plants are pretty much clones of each other. And I hear that there might be a plant being built in Colorado in the near future.
Go to:
http://www.thermocoremo.com/Give them a call, ask for Mikey.
Good Luck,
