Posted By jvwitt on 05/04/2008 4:38 PM
is it safe to install peel and stick membrane on sip roof and walls
Opinions differ, but the consensus is
no. You always need a way for a structure to dry if it gets wet(it shouldn't happen, but if it does). With SIP tape (should be required) on the inside, the outside is where the moisture must go.
I do recommend a 'peel & stick' membrane around all openings(extending inside) and at the exterior corners.
