Posted By the_glassman on 09/22/2008 10:48 PM
I like rigid foam so much I've decided to put another 1/2" of Dow Super Tuff-R on the outside OSB on my SIPs, but what is the general consensus in regards to the house wrap and foam order? Should I Tyvek the OSB first, then put the rigid foam on top of that, or should I do it the other way around? Also, foil side out or in?
Probly no tyvek needed, read the specs from
DOW
