Posted By Erin on 02/03/2009 12:05 PM
So, I'm trying to decide how best to approach both a vapor barrier as well as a radiant barrier.
Spend a bunch of time at www.buildingscience.com, especially researching the articles about designing for cold climates. You'll probably realize that you don't want to use a vapor barrier, you will want to seal every possible air leak, and insulation on the underside of the roof is better than radiant barrier. Radiant barrier has definite benefits, but it's not the be all to end all. If you do go that way look at OSB roof sheathing that has an aluminized bottom side. Other than in the attic, radiant barrier is mostly a waste of money. Take a good hard look at insulation systems as discussed on that site. You'll find the pink panther does a better job of hyping than saving energy.
