ErgoDesk
| 04 Sep 2009 06:26 PM |
Lesson #1 - Why you won't find Polyurethane ICFs on the job site.
Answer -
Build Smarter with Structural Insulated Air http://StyroHomeNews.blogspot.com |
ErgoDesk
| 05 Sep 2009 02:05 PM |
1. The foaming process creates a "skin" that prevents Concrete from bonding to the foam. |
arkie6
| 05 Sep 2009 04:19 PM |
Why does the structural concrete need to bond to the foam in an ICF assembled wall? |
Torben
| 05 Sep 2009 07:35 PM |
Then why do EPS foam SIPs use polyurethane adhesive to bond to the skins? |
ErgoDesk
| 05 Sep 2009 07:53 PM |
Hey My WHY? was first. |
Torben
| 05 Sep 2009 08:01 PM |
Okay your why first... Because EPS is cheaper than polyurethane. |
ErgoDesk
| 05 Sep 2009 08:04 PM |
Yes I agree, also EPS is better at insulating, so Cheaper and Better. |
richm
| 05 Sep 2009 08:39 PM |
ergodesk,
can you give facts as to "EPS is better at insulating". I am trying to figure all this stuff out and a factual answer with a source would really help!
richm |
ErgoDesk
| 05 Sep 2009 08:47 PM |
Sure, http://www.epsmolders.org/ |
ErgoDesk
| 05 Sep 2009 08:54 PM |
Environmentalists complain that EPS will not break down in land fills, but you never hear that about Polyurethane foam. Why? |
richm
| 05 Sep 2009 09:41 PM |
ergodesk,
Just read the info at EPS Molders Assoc. I could not find where it said that EPS is better at insulating. They sure did write alot about the "aged" (or longer - 10 to 15 yrs) R values of polyurethane and iso. Tests have shown it to go down to 5.6/" whereas EPS lost no R value. That is very good to know.
It was also interesting to see their calculations for equal R values per x inches of material at prices that I have no idea as to the accuracy of.
Does anyone know the current price of 1 lb. density EPS, 1.2 lb EPS and polyurethane (NOT iso!!!) per board foot?
I would like to see some data collected since those tests were done in 1992. Do you know of anything in the works? There must be something - that was 17 years ago!
Also, please tell me if this should be a new thread:
Does anyone have experience with the relatively new EPS from BASF - Neopor. I have researched all I can find and it looks to be the next generation of EPS. Higher K factors, perhaps stronger, no info as to price. Is there a manufacturing plant in the US? All info I have found refers to it being from Germany.
Thanks for all the info all you contributors give! richm |
ErgoDesk
| 05 Sep 2009 10:17 PM |
I would suggest that you contact many of the builders using the NEW BASF EPS Foams.
cmkavala
| 06 Sep 2009 11:38 AM |
Posted By arkie6 on 09/05/2009 4:19 PM Why does the structural concrete need to bond to the foam in an ICF assembled wall? Arkie6; you hit it on the head, it does not need to bond at all as it is not part of the structural component. It is a thermal element of the wall |
Chris Kavala info@southernsips.com 1-877-321-SIPS |
