Posted By Alton on 16 May 2010 10:20 AM
About the only thing that can happen in the middle of a chase is for the wire to be tied together without being in a junction box. I had seen some strange electrical work in attics where homeowners have modified the wiring.
That would actually be quite a challenge. I like the SIP chases, but the wires do tend to snag in the EPS whenever they can, like entering and exiting. With wirenuts, I think you'd tear a new chase.
We did make the mistake yesterday of pulling a 90 (horizontal to vertical chase) - not a good plan. Next time I'd cut an access at the intersection and pull the wire in to two pulls. One wire, pull it horizontally and out the access, then vertically up the chase and backfill the access. Or put an outlet there (or box) and pull it as two completely separate sections.
The chases take a little figuring out - they are a little different - but I don't think that they're enough of a problem to want to take Chris's suggestion and fur-out (although he has other reasons why you might want to do that).
