Been a while since I posted here but I've got great news. We have developed a new Hybrid SIP system that is far superior to standard OSB SIP systems. Most shingle manufactures will consider the shingle warrantee void if shingles are applied directly to standard SIP roof panels. Our roof panels a manufactured with plywood (not OSB) and have a 1.5" air space above the 10" of EPS foam. Our roof panels also arrive at the site with T&G ceiling material applied and stained creating both the ceiling and the soffit completely finished. Once assembled the roof is absolutely complete except for the installation of facia. Wall panels can be purchased as panelized frames c/w spray foam or as regular SIP walls. We also have a hybrid wall SIP that has a wire slot open to the inside; these Hybrid SIP walls are ready for wiring and drywall. Our Hybrid homes kits are post & beam systems - they look amazing.
Larry S. [
[email protected]]
