RenoArch If your mgo board longer than 2440mm,it is easily curl after stack on the pallet.There are three main factors cause the curl 1.Manufacturer's base board is too old that already curled. 2.Long time stack on the pallet. 3.big temperature difference. About the crack,you can drill before you fix the boards on the steel frame with screws,and keep the screws a little bit far from the edge of the board.It is effective to avoid the crack. You mentioned shrinkage after installed,I think your local temperature is cold.Expansion and Shrinkage can't be avoided due to mgo's physical characteristics.So when you install the boards,you should leave about 10mm between two boards and use the elastic joint compound(elastic putty) in the connection.It can avoide Expansion and Shrinkage obviously. Hope it help u. |
