We have a SIPS house that's 20+ yrs old. In the right light, a couple of the seams of the ceiling panels can be seen from inside on the drywall ceiling. It's not significant and it's only about 4 seams in the whole house, but I was just curious what causes this. I've read about a "ghosting effect" that I can see from the outside when there is frost on the roof. Do the visible seams on the inside have something to do with condensation or moisture coming through? Or maybe panels that don't quite line up perfectly? Like I said, you can only see it in the correct lighting, most of the time it's not noticable and doesn't crack the drywall. Just curious. I'm sure the age of the house has something to do with it. Thanks.
