Posted By SimonD on 14 Feb 2011 11:37 PM
If you don't have access to the outside face of the walls, unit masonry is the most practical and cost effective.
Chris K, can you explain how they would assemble your rated wall assembly given their situation of infilling between two townhouses?
Your wall assembly probably has a 1 hour non load bearing rating. That's not a problem I guess, you just have to support your floors & roof with the front and back walls.
Oh my gosh, I avoid block as much as possible, scaffolding three stories, it is not at all cost effective or practical to bring in another trade when the SIP framer can accomplish it,
No infilling needed ........balloon frame wall
Simon ...... Don't assume anything! Our SIP wall assembly is a 1 hour
LOAD BEARING assembly ( 1299 # per LFT)
Notice this picture with partywall supporting 2 roof box beams, one from each unit
